More Camber On One Side :/
Trying to get my fitment right and my back right (facing the front of car) tyre is rubbing and my back left is perfect. I have standard camber arms, the car is a 93 EG civic hatch. I have a wheel alignment report which says:
Final:
Left -2'54
Right -3'12
So im unsure if the left and right is from facing the rear of the car which would make sense if I am getting rubbing, but what I dont get is that I have standard camber arms, the suspension is of equal spec on each side so why is there more camber on one side?
Final:
Left -2'54
Right -3'12
Some variance side to side is expected, and if those are in degree minutes notation (or whatever the proper term is) it doesn't seem that far off.
What are "standard camber arms"? If you have a camber kit, that isn't standard and needs to be adjusted to bring the two sides to the same value. That's also quite a bit of camber for a 93 hatchback, how dumped is the car?
excuse pic of the bonnet in first pic, just got it freshly painted
Well if they are the stock arm and been there for 15+ years , most likely all the bushings from toe,camber,lca are worned and that can cause uneven settings like what your dealing with now, camber.
Best bet is to get adjustable camber arms, and dial however you desire.
