Vacuum Line
Old Jun 1, 2011 | 09:53 AM
Bwhit12's Avatar
Default Vacuum Line
Looking for some assistance from all of you geniuses. I have spent a couple hours searching and found a few different things, but nothing that has totally cleared up my question.
I am in need of the vacuum line diagram for a boosted setup. I know I run a line from the BOV to the IM, but I am more confused on the two lines I will be running from my wastgate.
Also wondering where can I purchase the oil T for the back of the block?
Thanks for the help ahead of time!
Old Jun 1, 2011 | 12:58 PM
4cylfiend's Avatar
Default Re: Vacuum Line
this should help. Found it on google..
http://imageshack.us/photo/my-images/541/bovhookup.jpg/
Old Jun 1, 2011 | 01:03 PM
myallmotoreg's Avatar
The line on top goes to nothing, The line on the side goes to the compressor housing on the turbo. A good place to buy the "T" fitting is Stealthmode Performance.
Old Jun 1, 2011 | 01:06 PM
Bwhit12's Avatar
Thanks for the info guys!
Old Jun 6, 2011 | 09:58 AM
Bwhit12's Avatar
Does this look good for the vacuum lines?
Old Jun 6, 2011 | 11:03 AM
4cylfiend's Avatar
Yes if you arent running a boost controller.
Old Jun 6, 2011 | 11:59 AM
civickiller's Avatar
It's not advised to t off the pressure sensor at the block. I would either buy a sandwich plate or a fiirewall sensor kit that flamenco t sells
FWD_BEAST
Mar 2, 2015 08:31 AM
seeeya04
Dec 1, 2005 06:40 AM
ion_four
Jun 24, 2003 08:11 AM
xci_ed6
Aug 10, 2002 05:35 PM
