clunk over bumps
Old May 30, 2011 | 08:29 PM
harleyhumper444's Avatar
Default clunk over bumps
My 2000 EM1 civic makes a clunking noise going over pretty much any size bump and i have a little play in the steering wheel. What could be possible causes? It dosent seem to pull in either direction. I havent had the car long and it has 155k mileage. I looked through the paper work that came with the car. One of the sheets had a repair order, all it said was "customer complaint: pulls to one side at speeds over 45mph, fix tighten suspension bolts" if that matters. Im a noob at suspension.
Old May 30, 2011 | 09:35 PM
Jimmy's Avatar
Global Moderator
Default Re: clunk over bumps
If possible I would try to get the car up on a lift and raise it check everything out, check the wheels for play.. tie rods & wheel bearings.. check the bushings and all suspension components/bolt's etc and just go from there...
Old May 30, 2011 | 11:26 PM
Arcitekt's Avatar
MOB Mentality
Jimmy nailed it pretty much. take it to a mech.
sde780
May 24, 2008 07:41 AM
benmasters
Sep 17, 2004 03:05 AM
civboy115
Dec 23, 2003 09:01 AM
brbHPR
Aug 26, 2003 09:41 PM
