ITR Suspension Checking/Problems
Old Sep 17, 2004 | 02:28 AM
benmasters's Avatar
Default ITR Suspension Checking/Problems
Hi All,
Problem with my ITR, recently the front wheels have felt unbalanced, and before I went to get them re-balanced i thought I would just have a tug on the wheels and make sure there is no play......
The front left wheel when tugged at the top and NOT jacked up seems to have about a 1-2mm movement in it, I can feel it knocking backwards and forwards when push/pulled. The movement comes from the top half and upwards of the hub, almost sounds like upper ball joint.
But When I jack the wheel up and the check for play 9-3 or 12-6 there is nothing, which kinda confuses me and when i tug the wheel and place my hand round the upper balljoint I cant feel anything.
Any body got any pointers/direction?
Is there a guide that anyone has that I can work through to check suspension? Its really hard to check for movement if a wheel is off so what do you guys all do? or more importantly how.....
BTW - she has done about 70k
Old Sep 17, 2004 | 02:35 AM
Willard's Avatar
Default Re: ITR Suspension Checking/Problems (benmasters)
check the condition of the rubber bushings?
Old Sep 17, 2004 | 02:44 AM
benmasters's Avatar
Default Re: ITR Suspension Checking/Problems (Willard)
Ok will check, doesn feel like a bushing thou if you know what i mean, feels like a balljoint worn, you know like a clunk clunk rather than play in a busing.
This may sound stupid but how would you check bushings - just a visual inspection?
Old Sep 17, 2004 | 02:46 AM
Willard's Avatar
clunk =
bushing check = large screwdriver/pry bar. just try to move the bushign around and see if it clunks.
Old Sep 17, 2004 | 02:54 AM
Blind-Fashion's Avatar
just wondering if it feels unbalanced all the time? or just under braking?
Old Sep 17, 2004 | 03:05 AM
benmasters's Avatar
Default Re: (Blind Fashion)
No its not under braking its around 60-70 and only very slightly when no turn is applied i.e when going straight, I actually noticed it was more pronounced after heavy acceleration, i.e when the front end is lifting.
clunk = A dull sound; a thump. A blow that produces a dull sound. To make or move with a clunk. To strike something so as to make a dull sound.
You know if a ball joint had play you could imagine moving it back and forth and hear/feel clunk clunk as it hit the side.
markass420
May 25, 2013 10:21 PM
FrodeyEJ1
10
Oct 18, 2012 10:15 AM
harleyhumper444
May 30, 2011 11:26 PM
sde780
May 24, 2008 07:41 AM
Ditdogs
Mar 29, 2004 03:10 PM
