Lst Build Questions
Old May 30, 2011 | 12:34 PM
1SIKEK4LS-T's Avatar
Default Lst Build Questions
Hey H-t,
b18b1 with hyrdo tranny 80K on both
Pieced together Turbo kit(no ebayjunk)
440's(RC)
GARRET T3/T4 60 trim
Custom made exhaust manifold
Custom downpipe
Custom made vacume box
After Engine is built and all together Heading to.. Babylon ,N.Y -NRG Tech
Gunning for 300 whp at the dyno
Full oem Honda gasket/seals
Moroso baffled oil pan
Might Throw a B20 head On it For alittle more top end as the valves are a bit bigger what do use think?
Question for you gearheads..
What pistons and rods Should i buy?And what size pistons Standard?
What compression ratio i should go with?
I wanna blockgaurd the sleeves can a machine shop do this for me?
Or is it a DIY Project.
Spread your knowledge!!
Old May 30, 2011 | 01:12 PM
civickiller's Avatar
Default Re: Lst Build Questions
You can do 300whp on the stock motor
Blockguards are crap, don't run one
Old May 30, 2011 | 01:16 PM
AllShowNoGo727's Avatar
Dont waste money on a b20 head just put a Vtec head on it, if my block wasn't sleeved I personally would and did run a block guard on my previous setups.
Old May 30, 2011 | 07:13 PM
But with stocks rods and pistons and a good tune will it be relibal
Old May 30, 2011 | 08:18 PM
Good tune is the key.
How long it lasts also depends on how u drive
Old Jun 1, 2011 | 09:30 AM
lsturbo33's Avatar
With 440's on my b18b1 they were maxed at 280. Get bigger injectors. If your rebuilding just bore to 81.5mm.
Old Jun 1, 2011 | 10:23 AM
Ok,thanks for all the replys
i decided to just throw the kit on the motors a baby itll hold 8 psi daily with a real good tune
Old Jun 1, 2011 | 10:27 AM
idk why i quoted my own quote(zoooted) but i forgot to mention does anybody use the "GM" map sensor?? where do i grab one of the bad boys lol
Old Jun 2, 2011 | 05:28 PM
^ get an omni 4 bar, direct plug and play and looks clean.
Old Jun 2, 2011 | 08:08 PM
Stock map sensor can read up to 11psi but if you still want to get one, omni's is choice
Old Jun 6, 2011 | 01:39 AM
nicee so i can use my stock map cuz im only ganna run 7 pounds and i know how to drive a high boosted DA integra so i wont be beatin this up much at all maybe a couple pulls on the high way thats all
Old Jun 6, 2011 | 02:29 AM
94GSRMR's Avatar
Lst thread will end all your questions just look at the setups and they will let you know what you need
Old Jun 6, 2011 | 09:29 AM
Just make sure you get it tuned
crx-b18c
Oct 16, 2008 02:32 PM
b20vtechatch
Jan 18, 2005 09:23 AM
done
Oct 3, 2002 06:17 AM
eKb20Vtec
Apr 19, 2002 05:17 AM
