CEL 41 how to address
Old May 30, 2011 | 11:15 AM
Civic Racer X 7's Avatar
Default CEL 41 how to address
looked it up it says Primary Oxygen sensor heating circuit
is this as easy as spending $67 for a new sensor
or there some sort of wire loose etc that heats the sensor
how should I approach this
thanks
Old May 30, 2011 | 11:20 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: CEL 41 how to address
Might help to list your make/model/year
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old May 30, 2011 | 12:24 PM
1997 Honda Civic LX all stock
Old May 30, 2011 | 01:34 PM
Former User's Avatar
Is 7.5A dash fuse 15 blown?
Old May 30, 2011 | 05:07 PM
I checked several fuses none were blown
but in all honesty IM not EXACTLY sure which one is fuse 15
counting from the front of the car or the back and what direction
but I did look at several fuses none blown
Old May 30, 2011 | 05:09 PM
You find fuse box diagrams in the FAQs sticky.
Old May 30, 2011 | 05:19 PM
it says fuse 15 is alternator , VSS, ELD ,EVAP purge, and oxygen sensors
my battery hasnt died so I assume alternator is working
and the speedometer is working so I assume the circuit is operating correctly?
just went out to car pulled the 4th fuse counting from the left in the middle row
thats the one the diagram says
it was a 7.5 and it "appeared" good
Old May 30, 2011 | 05:24 PM
That's the fuse. Test it to be sure and, if good, test that voltage reaches the O2 sensor heater element pin in the O2 sensor connector. If that's also fine, measure resistance of the heater element.
Old May 30, 2011 | 05:30 PM
Will do so tomorrow , quick question tho out of the for wires on the O2 connector WHICH pin is the heater element
could this all be bypassed by just buying a new sensor?
Old May 30, 2011 | 05:34 PM
The two black wires on the O2 sensor side are for the heater element. One is power from the main relay and the other is ground on the ECU. Measure resistance across the two black wires and voltage to body ground to one of the two corresponding wires in the wire harness connector.
Old May 30, 2011 | 05:39 PM
ok I have a multimeter that electricians use
can I measure resistance with that?
I know it will check voltage
Old May 30, 2011 | 06:23 PM
Yes. Post the Ohm reading.
Old Jun 1, 2011 | 02:50 AM
ok I had 12.46 volts to the plug side
and when I switched the meter to read OHMS
I would put one side of the tester on one of the black wires prongs
and the other on the other prong and got NOTHING
tried several times in case wasnt getting connection
no reading
Old Jun 1, 2011 | 04:56 AM
If you touch the two probes of the meter together, what Ohm reading does the meter display?
If you separate the two probes of the meter, what Ohm reading does the meter display?
Which reading did you see when you touched the two black wires with the meter probes?
RVMIRXZem1
Oct 26, 2018 07:05 PM
Devious951
10
Aug 29, 2009 10:22 AM
_Bug_
13
Feb 22, 2006 07:30 AM
delsolcrazy
May 5, 2005 03:06 PM
hitvtecgetloud09
Nov 12, 2004 02:42 AM
