Sunpro Tach messed up my car?
Old May 28, 2011 | 05:56 PM
doefat04's Avatar
Default Sunpro Tach messed up my car?
Ok so I bought an 2" sun-pro tach for my 98 cx and I hooked up the red wire to fuse 28(accesory) and the white wire to fuse 31(dash light) Black wire to a gold bolt under steering adn the green wire to the blue dead end wire on the driver side right by where all the wires come out the firewall.
Now my car cranks cranks cranks and nothing. After a few trys it turns on but the idle is all off and it shuts off. I though it had no gas but I put a gallon in. All this happens only after I installed the tacho. On one it shows rpms at .5 then next time it turned on at 2.5 and dropped to 1? WTF IS GOING ON!! (hangover yell) Plus I disconnected everything and now I get the same problem. Mind you my car was working smooth as a babys ***. HELP PLZ. It just got dark so my saturday is ****ked.
PS yes its on 4cyl
Old May 28, 2011 | 06:53 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Sunpro Tach messed up my car?
I don't think it was the tach that messed up the car.
Old May 28, 2011 | 07:01 PM
doefat04's Avatar
update ....Ok bad ground....but now my car idles at .5 and vibrates pretty hard. any ideas?
Old May 28, 2011 | 11:39 PM
doefat04's Avatar
Old May 29, 2011 | 01:33 PM
doefat04's Avatar
ok so now I rewired everything correctly and nice and now car wont start again or it will start and putter off 2 seconds later??? anyone?? I gotta go to work tomorow!
Old May 29, 2011 | 01:46 PM
The Grumpiest
Won't start? As in cranks but won't turn over or won't crank? More details please.
Old May 29, 2011 | 02:03 PM
The Grumpiest
So much for getting to work tomorrow.
Old May 29, 2011 | 04:23 PM
doefat04's Avatar
yea I got it running and after driving about 10 min it shuts off. Whats funny is that it takes a million times to start and when I crank and turn on my headlights it seems to fire up? WTF is going on? all this because of a tachometer install that was very simple. i have read that maybe the coil busted but how do i check that? what do you think?
Old May 29, 2011 | 04:39 PM
The Grumpiest
Test it.
http://www.clubcivic.com/board/showthread.php?t=180000
slimjimdanny
Jan 31, 2007 07:35 PM
bbhockey19
10
Jul 11, 2006 09:10 PM
andyboy
11
Mar 17, 2004 06:35 PM
cpizzy
Dec 31, 2003 08:39 PM
