Code 43 Help
I recently changed my distributor and today got my hands on a timing light and decided to set the timing. The directions i got said to start the car and let the fan cycle on/off once before putting in the jump wire. After about 5 minutes with no fan I got impatient and started to give the car a little gas to heat it up faster. After about 30 seconds of 2.5k rpms the check engine light came on. I shut the car down and checked the code, read 43 which is a fuel supply problem.
The next time i turned the car over the light was off but the code is still showing if I jump it. I had already loosened the bolts on the distributor a little.
I'm new to hondas so I'm wondering if it is possible the distributor turned a little bit when under throttle and caused the engine to run lean and trip the code.
Also since the light is off does that mean the problem is gone and I just need to reset the computer some how or should I start looking at the fuel system.
Any help would be great
Sorry
Its a 93 civic LX
I haven't unplugged the computer yet. I am assuming that is how to reset the codes? Honestly had no clue how to reset them. I'll give that a try and hopefully it will show clear.
Thanks
Its a 93 civic LX
Thanks
waynesumner
18
Jun 26, 2013 07:42 PM
JDM DC2 R
Mar 13, 2003 01:19 AM
