anyone use SRP pistons in 550-600+whp?
Old May 28, 2011 | 03:02 PM
Cimburke23's Avatar
Default anyone use SRP pistons in 550-600+whp?
I am making 600+whp and had a weird clicking noise develop after the last time at the track, start looking and after pulling the pan, windage tray and etc i am moving the crank and notice oil squishing between the wrist pin and the piston on my SRP's. i called the tech line and they said the max power these pistons are rated for is 400-450whp. has anyone else ran them with any type of higher horsepower and had this problem? I am going to buy CP or wiseco probably when i go to a sleeved block but just wanted other peoples take on this issue.
Old May 28, 2011 | 03:24 PM
EDVxRICHARD's Avatar
Default Re: anyone use SRP pistons in 550-600+whp?
im about 450+ on pump and 500+ on race....5,000 miles so far so good
Old May 28, 2011 | 03:43 PM
theidealone's Avatar
SRP is JE's "cheap" line. So Im not surprised theyre rated for such low power.
Old May 28, 2011 | 03:56 PM
SPOOLINmatt's Avatar
what was the piston skirt clearance?
Old May 29, 2011 | 06:39 AM
luck4rmkc's Avatar
I was running on 420 whp last year for 1k miles and didn't have any problems. This year I'm shooting for 550whp so I guess we will see how they hold up. What kind of problems do you think your having in relation to the wrist pin? Excessive piston expansion?
Old May 29, 2011 | 04:41 PM
Cimburke23's Avatar
piston to wall is right at .004 when i put it together, not sure what would have caused this as it only happened to 1 piston and its #2. the pin just moves up and down in the pin bore. i will be pulling the head and rod/piston this week to inspect it further
Old May 29, 2011 | 05:05 PM
porkythegrunt's Avatar
Do your pistons have that super thin intake valve relief wall too?
Old May 30, 2011 | 04:53 AM
Autoworks's Avatar
We've been making 500+ on our D16 SRPs for the last year or so.
doood
May 18, 2015 03:14 PM
Bigpasty
K Series
Feb 28, 2013 01:57 PM
HybridKOOP
Jun 29, 2007 11:11 AM
ninesecrx
Mar 5, 2007 04:44 PM
Fly1865
Sep 13, 2002 08:08 AM
