subwoofers stopped working
today i drove up into the skool parking lot and was chilling in my car. my subs were working and everthing but after like 10min they stopped working half way through a song my amp does not turn on the fuse on the amp is good wtf do i do? its a 1995 honda civic lx from the states with a stock d15b7 motor.
learn to use a multimeter, make sure you have 12v and ground going to the amp
if you do then check if your remote wire from the radio is still connected
hey guys thanks for all your help, sorry for the late reply i had prom after prom work and cscs, i finally found some time in class to reply, the problem was actually the amp, a wire broke off the positive inside the smp itself!
