subwoofers stopped working
Old May 25, 2011 | 05:40 AM
farhat civic eg's Avatar
Default subwoofers stopped working
today i drove up into the skool parking lot and was chilling in my car. my subs were working and everthing but after like 10min they stopped working half way through a song my amp does not turn on the fuse on the amp is good wtf do i do? its a 1995 honda civic lx from the states with a stock d15b7 motor.
Old May 25, 2011 | 05:56 AM
fcm's Avatar
fcm
Old Fart
Default Re: subwoofers stopped working
Make and model of amp and sub would be more help then MM&Y of car.
Have you tested the amps fuse or amps power cable fuse or just eyeballed them? 94
Old May 26, 2011 | 08:10 PM
3RDCOASTRACER's Avatar
check the connetion @ the battery and the fuse holder for starters.
Old May 27, 2011 | 02:30 AM
grumblemarc's Avatar
The Grumpiest
Probably overheated the amp and the protection circuit kicked on.
Old May 27, 2011 | 12:26 PM
nsxxtreme's Avatar
Someone needs to spend a little longer in school.
Old May 28, 2011 | 12:29 PM
0c00l's Avatar
Grammar police, because our world will never move on without them!
Old May 28, 2011 | 09:35 PM
Linked's Avatar
learn to use a multimeter, make sure you have 12v and ground going to the amp
if you do then check if your remote wire from the radio is still connected
Old Jun 6, 2011 | 05:18 AM
hey guys thanks for all your help, sorry for the late reply i had prom after prom work and cscs, i finally found some time in class to reply, the problem was actually the amp, a wire broke off the positive inside the smp itself!
Spazbaboon
Audio / Security / Video
Feb 26, 2007 03:36 PM
casmello
Oct 6, 2005 10:41 AM
ilikemyaccord
Aug 13, 2004 04:36 PM
InTeGrA_bLazEd
Sep 11, 2003 10:32 PM
GoodFella
Jul 18, 2001 05:18 AM
