Can I convert my EGs manual steering to power?
Old May 21, 2011 | 12:21 PM
GahhItsLee's Avatar
Default Can I convert my EGs manual steering to power?
I can't find a solid yes or no on this. I wanna put power steering into my 93 dx. It's going into the shop soon enough anyway so could I have it converted to power steering and if I can any idea how much it would run me? I get semi friend prices from this shop they arent full price but im not getting a super deal.
Old May 21, 2011 | 12:53 PM
vartok's Avatar
Default Re: Can I convert my EGs manual steering to power?
well, you will need the rack and pinion, which runs about 200 i believe, then a pump- ~$130 and the hoses... then plus labor... personally, i would just deal, seeing as how its going to suck on what little low end torque that DX has already... and add weight... will prolly loose some MPG in doing so.
Old May 21, 2011 | 12:57 PM
Linked's Avatar
rack and pinion, power steering subframe (cause manual one is different)
pump & reservoir
lines and hoses
i dont know if the crank pulley on the dx's came with the additional pulleys for ac/ps either
Old May 21, 2011 | 01:00 PM
Knownworldwide's Avatar
^good stuff right there. And Also as mentioned, P/S is nice, but your light civic can not be that much trouble for you to steer. I personally like manual steering, but thats just me.
Old May 21, 2011 | 01:11 PM
fleabag's Avatar
Do you REALLY need power steering? REALLY? If you add a few PSI to your tires, that might be enough for you to get by since low tire pressure can make steering more difficult.
Old May 21, 2011 | 01:38 PM
GahhItsLee's Avatar
I don't need power steering but it's a nice thing. Im not spending that much ill just buy a normal sized wheel and hopfully that will help some what. (the one on it now seems to have been made for a small child its TINY)
Old May 21, 2011 | 01:41 PM
fleabag's Avatar
Well heavy tires and wheels+ low tire pressure can make it difficult to turn. I'm finding it very hard to believe that there is any need for a power steering conversion. Then again, I do keep my tires at a higher pressure than most people do.
Old May 21, 2011 | 01:58 PM
GahhItsLee's Avatar
Yea i think the majority of my problem (now that im thinking about it more since you guys think its not a big deal) is that the wheel the car has is aftermarket and SUPER small. I definitely need to look into getting a full sized one.
Old May 21, 2011 | 02:00 PM
vartok's Avatar
pics pl0x?
Old May 21, 2011 | 02:11 PM
GahhItsLee's Avatar
The car is smaller so i guess its like normal for my car but even my sebring has an inch or so bigger wheel this thing feels so mini.
Old May 21, 2011 | 02:13 PM
98civdx's Avatar
Master Detailer
Depends, my car is a PITA to turn with out PS, my friend's, can't even tell it doesn't have it.
Parking lots/low speed turning is where your really going to feel it, and need some arm strength to turn it.
It was really funny to whats my friend try to turn my wheels, she was struggling soo much, i was laughing my *** off.
Yes, it is definitely possible to install PS into the car, however, friend prices or not this will be a expensive job. I can easily see over 1000 to do this, just in labor.
Old May 21, 2011 | 02:22 PM
GahhItsLee's Avatar
I guess ill aim for a little bit bigger of a wheel and just get used to it beyond that.
Old May 21, 2011 | 03:22 PM
fleabag's Avatar
TRY TIRE PRESSURE.. Add like 7 PSI to those tires and I'm sure you'll notice it's much easier to turn the steering wheel. I mean on my Civic, I keep wondering why the **** does it even have power steering when turning the wheel despite the engine being off is so easy. If I can get a measurable improvement in my idling fuel economy by removing the P/S belt, I'm just going to drain the system and just loop the lines. A lot of the difficulty in turning a car with P/S when the engine is off is having to move all that fluid that is in the steering rack from one side to the other.
Old May 21, 2011 | 03:56 PM
GahhItsLee's Avatar
That's what kinda pressure should I be aiming for? Its over 30 psi per tire right noe
Old May 21, 2011 | 04:53 PM
fleabag's Avatar
Try 40psi and see how it goes.. My tires are rated at 51psi and I keep them at that psi.. Rides a bit more rough but otherwise not a big deal..
Old May 21, 2011 | 09:29 PM
GahhItsLee's Avatar
I do live in back woods NY... My idea of a good rode is one i can actually make it down in my car.. Ill check the tires and see what they are rated for and go with that.
bizzle2288
Aug 27, 2012 05:29 PM
FTNW
21
May 28, 2011 09:45 AM
Toks
Jan 21, 2009 02:10 AM
92lxinprogress
Jul 14, 2008 05:27 PM
FrankencrxBHAM
Mar 2, 2007 10:50 PM
