Rebuilt B18b1 complete swap!!!
Up for sale is a B18b1, i bought the head and block brand new from honda... I rebuilt it to stock specs and only performance that is in the motor are Arp head studs and rod, main bolts.. It willcome with everything needed to swap it into acar... You will receive a b16 trans, brand new axles, b18b1 ecu, si shift linkage with skunk2 short shifter, all mount brackets for a ek civic, clutch masters flywheel, exedy clutch disk with a act pressure plate. Listed below are all the parts I have replaced on the engine...
-rings
-bearings main/rods/thrust washers
-front/rear main seals
-oil pan gasket
-head gasket
-intake manifold gasket
-exhaust manifold gasket
-valve seals
-cleaned and reseated valves
-valve cover gasket with rubber grommets
-ngk copper spark plugs
-ngk spark plug wires
-distributer cap
-distributer rotor
-water pump tube housing seals
-water pump
-timing belt
-cam seals
-fresh hone on cylinders
I have replaced almost everything you can think of with all brand new parts..
Im asking $1800 for the whole swap..WILL NOT PART OUT
Will add pictures later!
-rings
-oil pan gasket
-head gasket
-valve seals
-distributer cap
-distributer rotor
-water pump
-timing belt
-cam seals
1990 CB7
Feb 27, 2017 11:40 AM
angela_itr
May 21, 2005 01:51 PM
AlphaKennyWun
Feb 13, 2002 04:47 PM
