I'm rich biaaa
anyways I know this is not a tech forum, but all the knowledgeable people are on this side of the forum.
first of all I wrecked my car last year after being tuned at 620whp 99 ek hatch b20/vtec turbo gt3567r. dual walbro 1600cc pte
salvage the motor and put it in a 92 civic hatch with new turbo s300sx, and dual bosch 044
got the car started today and fuel is just pouring out of my downpipe (open) what could the be? I ran rich before but never had a huge puddle of fuel on the ground. it was just dripping. I cant believe that just switching pmps would be all to push fuel out the motor. car still idles even though fuel is pouring out the exhaust.
I hope it was condensation, I'm running E85 and I know it produces a lot of condensation, but the motor was running for less than a minute, and it was a liter on the ground smell and look like fuel, but it was late and poor lighting, will reload my tune tonight and try again.
a liter is excessive for sure, but you can run alcohol rich enough for raw fuel to come through the turbo and exhaust.
My speculation is: E85 clogged an injector during your downtime and it's hanging open. Your plugs would tell you what cylinder is getting washed. Also, check your fuel pressure, make sure you're not experiencing pressure creep with the 044's.
found the problem, hondata was not properly connected to the ecu, so it was running 1600cc injectors on a stock ecu. I reconnect the hondata and it was golden, ne problem is laptop not recognizing the ecu, its been a while since I work with it so I have to research.
the hondata is throwing a red light, cant pull any codes since I am not running a stock dash, and the laptop is not recognizing the ecu.
to get rid of the red light go to new calibration and choose the 1st map on the list stock itr load it to the ecu and it should clear the red light for you. Then load your tune.
the computer is not recognizing that the ecu is plugged in, I trying to see whats the issue with that.
PINKS
Mar 19, 2007 12:07 PM
