Problem shifting at high RPMS...
Old Sep 30, 2002 | 09:23 AM
Kev95lx's Avatar
Default Problem shifting at high RPMS...
Maybe this topic should be in the TECH section, but I'll post it here 1st.
I have a 98 ITR engine & tranny in my 95 civic LX.
Last week my clutch Master Cylinder gave up and I couldn't shift properly into gears. I had trouble in eery single gear. the garage fixed it by changing it and everything seemed fine.
This pass weekend I was driving on the highway and was @ about 6,700 RPM when I shifted into 4th. But I couldn't, my stick was stuck in neutral and I couldn't do anything. I slowed the car down and was able to shift into 5th if I'm under 5K RPM...so I did that, later I needed to downshift into 4th and AGAIN, I couldn't.
This happens when at the high RPMS. When I went from 2 -> 3 I had the problem ( I heard grinding when I went to 3rd..) and when I went from 3 -> 2 I had the same problem.
Could it be that the clutch lines need to be bleeded? or is it something worse with the tranny.
Old Sep 30, 2002 | 09:27 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Problem shifting at high RPMS... (Kev95lx)
Can you double clutch into any gears?
Old Sep 30, 2002 | 09:28 AM
Reid's Avatar
Global Moderator
Bleed the slave cylinder.
If that doesn't fix it, it is probably clutch related.
Which clutch are you using and how many miles are on it?
Old Sep 30, 2002 | 09:29 AM
Kev95lx's Avatar
Default Re: Problem shifting at high RPMS... (Rguy)
Not all the time. When I'm in the low RPM's, it's all nice and smooth.
I've got the OEM ITR clutch
[Modified by Kev95lx, 6:34 PM 9/30/2002]
Old Sep 30, 2002 | 09:31 AM
Nick248's Avatar
When the mechanic replaced the master cylinder, did he replace the slave cylinder too? If he didn't, then you should for it may be the problem. Rule of thumb, always replace the slave cylinder when the master is replaced. (an extra 40 bucks)
Try that and then get back to us. Let us know what the outcome is.
PS ..... always bleed the system.
-Nick
Old Sep 30, 2002 | 09:35 AM
Kev95lx's Avatar
Default Re: Problem shifting at high RPMS... (Nick248)
Thnx..i'm heading there tonight. we'll rebleed the system and go from there.
Old Oct 1, 2002 | 07:52 AM
Kev95lx's Avatar
Problem solved,
1st we rebleeded again the slave cyclinder, problem was still there.
finally we adjusted the pushrod under the dash and now all is fine.
alaskanlue
Jul 20, 2009 09:30 PM
YangFlavor
Transmission & Drivetrain
Apr 14, 2009 07:24 PM
joeboxer212
Nov 21, 2006 12:36 PM
95GSRTT
Aug 16, 2004 04:34 PM
HavokB18
Jul 26, 2003 05:32 PM
