Best D-Series Combo???
Old May 15, 2011 | 12:24 PM
JDMCL's Avatar
Default Best D-Series Combo???
ok so i have been searching for about 3 hours now looking for the best d-series head and block combo. I've searched all over; on this forum and a whole bunch more and i just can't get straight forward answer. I heard that the z6 block with the y8 head is the best. But Then i Heard the jdm d15b is the best D motor. All of this is so confusing. Thanks ahead of time for any help given. its greatly appriciated. PS. IM NOT GOING B-SERIES SO PLEASE DON'T REFER IT!!
Old May 15, 2011 | 12:29 PM
eddie422's Avatar
Default Re: Best D-Series Combo???
yea i would say the z6 block with the y8 head would be the best but thats talking about just a straight up n/a build the y8 block has a tendensy to have the oil pump go i forget y but im sure someone on here will clear that up for me but as for the head on the y8 is good mostly the intake manifold but if i was you i would just go for a staright up z6
Old May 15, 2011 | 12:39 PM
JDMCL's Avatar
thanks good info. Do you know the difference between the z6 and the d15b? is the z6 still the best choice out of these two?
Old May 15, 2011 | 01:06 PM
grumblemarc's Avatar
The Grumpiest
It's pointless to try and mix and match D-series heads and blocks in an attempt to gain horsepower. D-series are econobox engines. No matter what you may do to them, short of boosting it, it will be sloooooow. You will not be satisfied with the results.
Old May 15, 2011 | 01:14 PM
JDMCL's Avatar
Not true because ive been in a civic with a y7 block and a y8 head and its scraped gsr's and b16's
Old May 15, 2011 | 01:18 PM
The Grumpiest
Can I call bullshit now? Especially since a Y7 & Y8 pretty much are the same where the block is concerned and a Y7 & Y8 are both snails.
Old May 15, 2011 | 01:21 PM
JDMCL's Avatar
You can call whatever you want. I know what ive witnessed.
The Grumpiest
Did the other cars know you were racing?
Old May 15, 2011 | 01:29 PM
JDMCL's Avatar
Anywaysss take your B.S somewhere else. I know what ive seen!
Old May 15, 2011 | 01:41 PM
eddie422's Avatar
Post Re: Best D-Series Combo???
no i never messed with a d15 im new to the d series game i had a integra before my sol so the d is new to me but i do know about the z6 and y8 even though a have a y8 my cousin has a z6 and its deff bad i have not raced him yet but its quick
Old May 15, 2011 | 01:43 PM
The Grumpiest
This question is so open ended and filled with false assumptions. If you were in a D-series car that SUPPOSEDLY had the stones to "scrape" more powerful engines with only a head swap, then build it like that one. You already have the blueprint. What's the point of the question?
Old May 15, 2011 | 01:46 PM
apexi_rsx's Avatar
lol.... sounds like the b16 and gsr's need the driver mod. y7/y8 engine cranks only had 1 cooling oil holes in the crank as the older d16's like the z6/a6/zc had 2 holes on the rod journals. everyone blames it on the y8 oil pump but ive ran a y8 oil pump with no mods with ok oil pressure for 3 yrs. the z6 oil pump did flow better then the y8 but i dont see it being the problem unlike the crank issue. any d15 i would say is a weak choice and the rods are smaller. i think the best motor is the z6. the y8 tends to confuse people that are running chipped obd1 ecu's. most obd1 motors were running 16* btdc at idle and the y/7/y8/y5 all ran 12* at idle. also the y7/y8 cams keys are 4.5 degrees different. some people run y8 cams in z6 heads. to each thier own. if u looking for power just get a z6 and boost it.
Old May 15, 2011 | 02:30 PM
JDMCL's Avatar
The point is i want to know if there is something better. Thats why i made this thread. take your unecessary comments somewhere else!
Old May 15, 2011 | 02:33 PM
DumpdEJ6's Avatar
I like the tuna here
You should specify "better". Better for boost, better for N/A, better for MPGs? Are you looking for low end torque or high rpm power? What if one engine is "better" stock, while another responds "better" to bolt ons?
Point being, "which engine is better" is a difficult question to answer, if not impossible.
Old May 15, 2011 | 05:18 PM
JDMCL's Avatar
Ok well im looking for better as in a N/A build. I want a single cam that hauls *** and people think its a twin cam. I just want a setup that has the most potential when it comes to N/A.
Old May 16, 2011 | 03:07 AM
The Grumpiest
Not with only a head swap.
Old May 16, 2011 | 06:25 AM
foo fighters's Avatar
Hands down, the D15B is the best SOHC VTEC engine ever built!
Old May 16, 2011 | 07:09 AM
jdmrexx402's Avatar
x2
Old May 16, 2011 | 07:29 AM
Tyla12's Avatar
I have a z6 block with y8 head & a ex/si tranny i beat people with full y8's, and people with full z6's. And keep up neck and neck with ls swaps. Also it reallly depends on the driver and need to know the limit of your car and how to drive it.
Old May 16, 2011 | 11:41 AM
DSMAddicted's Avatar
If I were going to go D-series for my swap, I would have definitely gone with this:
http://causeforalarm.thecarthing.com...TEC/index.html
That's about the only contribution I can offer to this thread. Good luck with your choice!
-Walter
Old May 17, 2011 | 06:22 AM
300whpej's Avatar
stock for stock the z6 or d15b are the best d-series motors without a doubt.
92ehatch
Jul 21, 2005 11:43 AM
Daniel san
11
Mar 7, 2005 08:10 PM
93slmdcvcsi
12
Jul 24, 2004 02:12 PM
Vinceg99
Sep 12, 2003 12:57 PM
SpoonPoon
Aug 29, 2003 09:15 AM
