b20 vtec turbo S300 Help!
Old May 15, 2011 | 11:51 AM
EGB20vtec-turbo's Avatar
Default b20 vtec turbo Hondata s300 WONT START! Help!
I have a 94 civic cx with a b20 vtec turbo.
Stock b20 block
stock b16 vtec head
t3t4 turbo
hks bov
aem feul rail
DSM 460cc injectors
stock map sensor
I've been working on this swap for over a year and can't seem to get it right, all I have right now is a base map to run on, but even on that, the car should start and idle.
I am getting fuel and spark at all of plugs.
New:
Dizzy
injectors
map sensor
plugs
On the graph it shows I'm getting any between 7. - 8. ms on fuel and IGN just stay's at -4 the whole time. I was told I could have the dizzy 180* out but I've tried moving it and still it's the same.
I have data log's if anyone wants to help me and and take a look, I'm not getting any IGN on the graph. But I'm getting spark to all 4 plugs and its a brand new dizzy.
Ask any question's!
Old May 15, 2011 | 12:02 PM
Default Re: b20 vtec turbo S300 Help!
Come on guy's I need some help to get this thing going!
Bump
Old May 15, 2011 | 12:20 PM
Man this site moves fast, not what I'm use too!
To the TOP!
Old May 15, 2011 | 12:30 PM
ttt
Old May 15, 2011 | 01:13 PM
grumblemarc's Avatar
The Grumpiest
Stop bumping the damn thread every 10 minutes!
1) You should have posted this in the proper forum-Forced Induction
2) Given WAAAAAY more detail than you have.
Old May 15, 2011 | 01:14 PM
evilclown312's Avatar
You dont need to bump it each 10 minuites dude, im sure someone can help you, you just have to be patient, if you want help right away, dont expect it too come from someone thats helping you for free...
EDITE: Grumb beat me too it
Old May 15, 2011 | 01:23 PM
I've never been on a forum that moves this fast, my bad for not wanting my thread to end up on page 44.
I'm just tired of working on this car, I'm ready to find out what the problem is, any help would be appreciated.
Old May 15, 2011 | 01:27 PM
The Grumpiest
More. Info. Please.
What have you done? What have you tried for a fix in this past year? Injectors spraying? Timing correct? Complete setup IN DETAIL. Is there a reason you just haven't taken it to a shop by now?
Old May 15, 2011 | 01:30 PM
Originally Posted by grumblemarc
More. Info. Please.
More info added.
There isn't any shop's around here that know what they're doing.
I had this whole setup in a 91 crx si and it worked perfect, the shell was just rusted out bad so I swapped everything to this EG.
Old May 15, 2011 | 01:36 PM
This photo was taken today
This photo was from when the car was idling. Notice it had IGN.
Old May 15, 2011 | 01:37 PM
as you can see, while I'm trying to crank the car I have plenty of feul, but no ignition....But I'm getting spark at the plugs.....what the hell?
Old May 15, 2011 | 01:45 PM
The Grumpiest
Old May 15, 2011 | 01:54 PM
Someone said it was the injectors at one point, because it was idling but would cut out and die if you gave it any throttle at all. Also sometimes the car would have fuel, sometimes it wouldnt. so I replaced the injectors, now I'm getting good ready fuel flow.
Someone said it sounded like a map sensor, so I bought a new one....
someone said it sounded like my dizzy was going out, so I bought a new one.
In the beginning I had a s200, someone said it was my ecu, so I bought another p28 and sent it to Hondata for them to install a brand new s300.
brand new IAC
new IAT
Oh, my tial bov was leaking, someone said a boost leak like that could cause it not to run, so I bought a HKS bov.
I bought all new fittings and hoses and done a boost leak test and fixed all leaks.
I have done alot, so much I can't even remember, this has been a on going thing for over a year...
Old May 15, 2011 | 03:25 PM
bump for added photos
Old May 15, 2011 | 08:35 PM
Bump
Old May 16, 2011 | 10:44 AM
ttt
Old May 16, 2011 | 09:36 PM
ttt again
Old May 17, 2011 | 02:24 AM
The Grumpiest
This is in the wrong forum. You would get better answers if it was moved to Forced Induction.
JohnstonOctober
Engine Management and Tuning
17
Jul 18, 2018 07:28 AM
MEn'MYEK
Apr 16, 2012 06:43 PM
boosted20psi
Jan 15, 2011 10:40 PM
earlboy77
Apr 24, 2009 05:42 PM
hbboostman
24
Jun 19, 2007 08:32 PM
