Timing Problem NEEDS HELP ASAP
Old May 14, 2011 | 11:26 AM
JDM^Johnny's Avatar
Icon2 Timing Problem NEEDS HELP ASAP
HI i got a 95 civic coupe...i did a 95 integra ls swap to my car
and the timing was off...i couldnt get it to be on the right spot for it to run'
right at all after putting on a new timing belt and water pump...
i try everything that i could find on the net butta still couldnt get it to run right
some how its short on power and tourqe...
anyone that has any idea please help me out!!!
Old May 14, 2011 | 11:29 AM
ricky00's Avatar
Default Re: Timing Problem NEEDS HELP ASAP
put ur crank on tdc on cylinder 1.. and put ur camshaft up... put the timing belt in and use a timing gun to check it.. always works for me
94dxcoupe's Avatar
you need to make sure the crank pulley shows its at TDC (white mark) and then line up both cam gears
Old May 14, 2011 | 11:33 AM
JDM^Johnny's Avatar
I try that already butta still when i start the car up the timing is off again
and when i adjust the dizzy the motor idle bad as hell
Old May 14, 2011 | 11:34 AM
JDM^Johnny's Avatar
I try that and whenever i start the car up it wont come back to TDC
and when i try adjusting the dizzy the motor idle bad as hell
Old May 14, 2011 | 11:37 AM
ricky00's Avatar
than u sure u got the right water pump and belt for ur ls???....
Old May 14, 2011 | 11:51 AM
JDM^Johnny's Avatar
yea im pretty sure
Old May 14, 2011 | 11:52 AM
grumblemarc's Avatar
The Grumpiest
Pretty sure? You either did or did not.
Old May 14, 2011 | 11:56 AM
JDM^Johnny's Avatar
aite im sure cuz i got them brand new from advence auto part
Old May 15, 2011 | 12:17 AM
team 15's Avatar
r u sure ur cams are aligning correctly cause when i did my friend's 94 ls timing i had to sweak the cam. Even though the cam is up, i still have to turn either the intake or exhaust cam by one teeth to make the car run right. DON'T KNOW WHY.
Old May 15, 2011 | 05:06 AM
civichxtreme2's Avatar
Try adjusting the TPS, Had that happen on an LS tried for a week to get the timing right and ended up having a tps way out of whack
Old May 15, 2011 | 08:55 AM
98civdx's Avatar
Master Detailer
Are you talking about mechanical or ignition timing?
Old May 15, 2011 | 05:51 PM
JDM^Johnny's Avatar
yea im sure that my cams are aligne correctly butta maybe ill try to do wat you did and see how its gonna run like..thanx btw
JDM^Johnny's Avatar
aight thanx ill try this too and see wat happen
Old May 15, 2011 | 05:52 PM
JDM^Johnny's Avatar
mechanical
alex14
12
Sep 29, 2010 01:01 AM
volcomstoned805
Jun 7, 2009 09:31 PM
marecco
Sep 7, 2007 01:12 PM
forcefedferio
Aug 23, 2006 03:48 AM
redcrx1
Nov 29, 2003 06:40 AM
