vtec solenoid issue?
Yesterday car ran real good, Vtec engaged perfectly, today when I drove to lunch I noticed there was no Vtec go, stopped ate, then drove back to work, when I mashed it and it got to Vtec rpm motor would shudder real bad and bog down, I pulled over and everything is still plugged in, revved from under hood and same and I hear chirping when Vtec is suppose to turn on.... what's this mean?
vtec only engauges when the car is under load not in neutral or park. are u getting any CEL's? Is your oil level low? Vtec will not engage if you oil is low on the dip stick.
i got it working, yea theres enough oil, the oil pressure sensor on vtec solenoid is messed up, green one, plastic all broke off and 2 prongs, 1 is barely hanging on...
