knock sensor problems!!!!
i have an lsvtec swap in my 90 crx si. b1 block, jdm b16a1 head, pr3 ecu. my vtec isnt cracking very hard and i have a check engine light on. i'm told its cuz the b1 block doesnt have a knock sensor and my ecu has the wire for it. how do i fix this so that my check engine light turns off and my vtec cracks right? by the way i'm running obd0
Last edited by jarhead90crx; May 11, 2011 at 03:46 PM. Reason: forgot to add my obd code
Easy! Add a knock sensor.
http://www.team-integra.net/forum/14...sor-b18b1.html
.. but FIRST check your ECU and make absolutely sure that you are getting a knock sensor CEL code.
(Currious - what ECU are you running anyway? PR3 I'm guessing?!?!)
SivikHatch
Jun 29, 2004 04:18 AM
