d16z6 Cel 6 replaced sensor twice still on
Old May 11, 2011 | 10:32 AM
Crashtestdummy's Avatar
Default d16z6 Cel 6 replaced sensor twice still on
just as it says d16z6 motor throwing a cel 6, which is a coolant temp sensor, i've replaced it with actually 2 different sensors now after i broke the original this morning trying to get it out lol. I pulled the back up 7.5 fuse, and then after it was still on i pulled the battery cable. I can see no visible breaks in the wire for the part thats uncovered. I'm at a loss for what to do next, any ideas?
Old May 11, 2011 | 10:38 AM
Former User's Avatar
Default Re: d16z6 Cel 6 replaced sensor twice still on
The ECT sensor has two wires and is located below the distributor. Is that the one you are replacing?
Test the two ECT sensor wires for a short or open. This requires a multimeter.
Also check whether the ECT sensor plug gets 5 reference volts from the ECU.
Old May 11, 2011 | 10:40 AM
Yeah thats the one i'm replacing, its made out of brass and screws into the block under the distributor, i'll test the wires and get back to you. thnx
rizzuto_usmc
Sep 21, 2012 05:31 AM
Unphzd
Dec 13, 2010 11:30 PM
Crashtestdummy
Sep 21, 2010 05:06 PM
Cataclysmic
11
Aug 3, 2009 01:57 PM
Snydog0510
Jun 16, 2003 08:52 PM
