d16z6 o2 sensor testing..
So I grabbed a voltmeter and tried to test my o2 sensor. I ran the ground to the ground terminal of the battery and put the positive onto the white sensor wire. I'm not sure if I did it right but I put the voltmeter sensor into the white wire hole on the clip.
I let the car warm up and it read anywhere from as low as .063 up to .21. After four minutes, it still stayed within that range. I then tried to rev the motor around 2k with some help and the meter read the same.
Does this mean the sensor is bad? Never done this before.
Re: d16z6 o2 sensor testing..
why are you checking the o2 sensor? is it throwing the o2 sensor cel? if it is just check your wires and if they look good then just replace the sensor no need to check it. if its throwing the cel is because is bad.
Wanted to test o2 because people said to. Just checking to make sure I did it right.
Do you think you could send me the instructions for a resistance test and the expective values returned on the meter?
Dioxine
16
10-04-2016 02:45 PM
