bad starter signal?
Old May 11, 2011 | 08:40 AM
slowassBubble's Avatar
Default bad starter signal?
ok so my car wont start at random times, i thought it was my starter so i changed it but it still does the same thing which is that it will click loudly, i thought maybe it was a bad flywheel but i gave the starter signal wire direct power from the battery and it turns over fine, at first it will do it like 2-3 times a day but it will start eventually now it just always clicks unless i put power to the signal.. i dont think its the main relay neither because i always hear the clicks and my fuel pump always primes...am thinking that the wire isnt getting enough voltage or maybe a lose ground...were does the starter signal get power from, were can i start checking for problems for the signal wire?....thanks guys
Old May 11, 2011 | 09:00 AM
Former User's Avatar
Default Re: bad starter signal?
The click sound suggests that the signal wire is activating the solenoid. Are you sure the starter solenoid is clicking?
Have you checked the rubber stopper for damage at the top of the clutch pedal and tried adjusting the starter switch that presses on the rubber stopper?
Old May 11, 2011 | 09:16 AM
NotAJDMFanBoy's Avatar
I had this problem with a coupe I bought. I replaced the main relay and a bad ground and it fixed it. If you don't have an extra main relay, get a soldering iron and heat all the joints up on the back of the board until they are liquid and dab a little more solder on them. The joints crack and that's usually why the main relays fail.
Old May 11, 2011 | 09:18 AM
A bad main relay would not prevent the starter from cranking the engine, which is what I believe the problem is.
Old May 11, 2011 | 10:06 AM
yea i guess ill have to check the clutch switch but yea i dont think its the main relay, starter solenoid get power because it always clicks and tries to start
Old May 11, 2011 | 10:34 AM
By signal wire do you mean the large wire for the starter motor?
Old May 15, 2011 | 07:45 AM
the small wire that goes to the alternator
Old May 15, 2011 | 07:50 AM
i just installed an engine start button
cksnah252
12
Sep 9, 2014 07:51 AM
SlimBB4
Nov 1, 2010 01:12 PM
mtber
Jul 14, 2004 09:02 AM
crx1856
Aug 20, 2003 10:24 PM
Bbasso
Apr 6, 2003 12:02 PM
