Mil on b16b in 99 si
Old May 10, 2011 | 08:28 PM
mgrcrx's Avatar
Default Mil on b16b in 99 si
Just purchase a 99 si with b16b in it. It's running on the stock Si ecu. The engine light is for camshaft position sensor short to B+ I also got a jdm p30 obd1 ecu. So if I connect a jumper harness and use the P30 will it go away. Need help
Old May 10, 2011 | 08:43 PM
Former User's Avatar
Default Re: Mil on b16b in 99 si
What is the specific CEL code? Post it.
Old May 10, 2011 | 09:11 PM
mgrcrx's Avatar
Will post when I get work
Old May 11, 2011 | 01:12 AM
HondaPartsHero's Avatar
Technical Hero
Just an idea but is the code P1337 for the CKF sensor since the B16B doesn't have one and the P2T will look for one. If so check here:
http://www.clubcivic.com/board/sitem.../t-159418.html
Old May 11, 2011 | 06:29 AM
mgrcrx's Avatar
Yea thats the one. Thanx
Old May 11, 2011 | 07:25 AM
99_EM1's Avatar
if that the case then there's a DIY to bypass it...i recently got a jdm block and found out bout that too and i bypass it in my 99 Em1...ran perfect with no CEL with my b16a2 ecu....here's the link..read it carefully...
http://ff-squad.com/wp/?p=309
Old May 11, 2011 | 07:28 AM
Si_chRis's Avatar
The JDM P30 can fix that code but a JDM PCT would be the correct ECU for the B16B.
If you want to use the USDM P2T ECU, you can do the CKF trick to rid of the code.
Old May 11, 2011 | 08:53 AM
mgrcrx's Avatar
Ok i perform the CKF trick and its not working for me so far. Know im doing this on obd2b harness, the wire colors for the second part are correct. Know its not C30 & C31, the correct location are C23 & C24. I perform part one and two did the quick-splice and cut the wires that are stated. So lets see
Old May 11, 2011 | 08:54 AM
mgrcrx's Avatar
I'm about to get a jumper harness and use the P30
Old May 11, 2011 | 08:58 AM
mgrcrx's Avatar
I since i perform the CKF trick, if i use the obd1 ECU do i have to connect everything back the way it was.
Old May 11, 2011 | 06:12 PM
Si_chRis's Avatar
Well, if you plan on using a JDM ECU, then no. I had to do the CKF trick for emissions but switched back over to my JDM ECU after. No issues.
Old May 11, 2011 | 06:27 PM
mgrcrx's Avatar
I use the jumper harness and my p30 no start. Plug all wires back to stock nothing either. Going to swap jumper with an other one see what happens.
miahmouse
Dec 11, 2003 09:38 PM
sshaikh01
14
Mar 2, 2003 04:37 PM
Civichatch2k
Feb 21, 2003 04:07 PM
