Need help with chugging idle
Old May 10, 2011 | 08:52 AM
brianjec's Avatar
Default Need help with chugging idle
Have a 2000 civic ex, 143k. For the past year or so, the idle has been pretty rough. You can her almost like a thumping noise coming from the exhaust. When I let off the brake to pull forward the car seems to chug or bounce until I get on the gas. I don't have any other problems during Ig normal driving. It also seems like it gets worse when the weather is warmer. Car had plugs, wires and a cap put on about 20k ago. IACV seems ok, it's the rotary type cuz my car is auto. Took it apart and cleaned it along with the throttle body. Compression numbers are around 105-110 across all cylinders. Any help would be appreciated.
Old May 10, 2011 | 11:23 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Need help with chugging idle
any CELs?
hit the enter key once in awhile
Old May 10, 2011 | 01:10 PM
brianjec's Avatar
No cels.
Car also has a fresh aftermarket cat on it.
Old May 12, 2011 | 12:07 PM
brianjec's Avatar
bump
Old May 25, 2011 | 12:19 PM
brianjec's Avatar
Got a cel the other day, went to advance to get it checked, p1302 number 2 cylinder misfire, p1399 no definition. Had them cleared and haven't had another since. Same problem still going on though
Old May 25, 2011 | 12:30 PM
Former User's Avatar
143K - it may be time to replace the distributor, which has a lifespan of about 150K miles.
You also need to do another ignition system tune up (OEM plugs, wires, cap, rotor).
Is the ignition timing set to spec?
Has the fuel filter been replaced?
Are you getting poor gas mileage?
Old May 26, 2011 | 09:23 AM
brianjec's Avatar
I'll have to check the timing, the timing belt was replaced at 105k per the service schedule.
Fuel filter was changed about 2 weeks ago, no difference there.
Gas mileage is normal, about 24 around town and between 33-38 on long highway trips.
Em1_coupe
14
Apr 8, 2015 10:09 AM
JDM H power
Mar 21, 2009 10:15 PM
manyakiexpi
20
Mar 2, 2006 12:05 PM
