(PRO) Not your average problem... HELP!!
Old Mar 20, 2009 | 04:27 AM
JDM H power's Avatar
Icon3 (PRO) Not your average problem... HELP!!
Ok so it all started when i wrecked the other day.. i fixed the main problem and to better understand please refer to the following thread: http://www.vadriven.com/forums/showthread.php?t=282209
1996 Integra B20B Stock.
So before i removed the TB and checked it, I was adjusting the TPS, The (idle i guess?) Screw on the throttle body, and the distributor... trying to get the idle and everything right. Well after i fixed the problem i couldn't get everything back to normal. Now running rich, bogging kinda up to like 3500 then runs and pulls hard like before. And when i barely push the gas it sounds like its on 3 cylinders like a misfire or something. Its bad when its cold but when its warm it idles high @ 2K RPM but still bogs till high RPM.
So my question is.. how do i adjust those three things back to or damn near factory settings?? (Idle screw on throttle body, TPS, and Distributor.)
Things i've done and replaced so far:
-Spark plugs, wires, cap & rotor
-Cleaned IACV
-Fixed bent butterfly inside throttle body (main problem)
Old Mar 20, 2009 | 04:46 AM
sirmugenpower's Avatar
Default Re: (PRO) Not your average problem... HELP!!
i got the same problem with my ls it ran fine when i bought it i pulled the motor and put it in another shell same make yeah and everything now it sounds like it's misfiring and spudders when i step on the gas it's weird iv'e done the same exact stuff replace and cleaned everything that it could possibly be but no luck yet
Old Mar 20, 2009 | 06:21 AM
mr.beeks's Avatar
Idle screw-- is simple just tighten all the way in and then let it loose slowly.
TPS--- you need to adjust to get the right reading (signal output) dont have the ##'s
timming--- adjust after everything is done
Old Mar 20, 2009 | 07:03 PM
angel_i's Avatar
Set your timing back to factory specs. Is it possible that when you hit, the distributor was hit hard enough to advance it(dizzy rotate towards the firewall).
Old Mar 20, 2009 | 08:36 PM
sp00ledbseries's Avatar
Ive seen cars take a hard hit and the dizzy take a **** or the ecu.
Old Mar 20, 2009 | 10:54 PM
DrGrEeNtHuMb's Avatar
Could be your igniter control module inside ur distributor, and checl the order of ur spark plugs. The misfiring sound is prolly ur engine misfiring lol. I had that problem before, after I did my vtec conversion. I doubt its your timing since you said it goes back to normal after a certain rpm. I bet anyone 100 bucks its in your dizzy
Old Mar 21, 2009 | 02:19 PM
Update: Set the timing by hand last night... started it up n used a timing light to check it.. its even more off than before.. can't even get the timing to be @ TDC. Im stumped and getting aggrivated n running out of money and time...
Old Mar 21, 2009 | 04:28 PM
Ttt
Old Mar 21, 2009 | 10:14 PM
connor53's Avatar
Try another distributor. I had a problem "similar" to this. replaced EVERYTHING in the distributor. Same problems, 350$ later. A friend dropped off a distributor, Threw it on and it went away. Completely rebuilt with all brand new parts from Acura but it wasn't good enough apparently. Whatever.
Another time inbetween changing Throttle Bodies I bent the bracket on the inside that holds the TPS. Got a new one, changed the throttle body and reset the TPS on my S300 and all was good.
Old Mar 21, 2009 | 10:15 PM
connor53's Avatar
Just a few things I could think of from my own problems. Hope it leads you somewhere.
philep_cb7_91
Feb 21, 2010 11:28 AM
SRZsmack
12
May 25, 2009 09:27 PM
theelemental
Nov 7, 2008 01:37 PM
WhiteSH
Aug 14, 2006 10:31 AM
boost'dsiR
12
Dec 17, 2005 01:00 AM
