what dash to use on oil catch can
what dash you guys using on your oil catch can and what is the difference between the -10 and -12. i am not asking about the size difference, just wondering which one to go with and why pick certain one. thanks.
Depends on alot. Whats your setup/How much power you making? Valve cover and block vented?
For 500-600whp setups, two -10AN on the block and two on the valve cover should be good. The more ventilation = less pressure in your crankcase which is a good thing.
-10 is fine, most people use -10 instead of -12 because of costs. Plenty of guys making over 1000hp with -10 catch cans. I honestly don't think there's much of a big difference between them as far as performance, 1/8ths of an inch is not much.
I run two -10 lines from the back of the block to one can, and two -10's on the valve cover to a separate can. Plenty of ventilation IMO. And for what it's worth, I run a pretty loose p/w clearance, and I still haven't had any issues...
TravisBiggie
Jul 3, 2012 10:48 AM
