Trouble shifting at high rpm's
Honda-Tech Titanium Member
Trying to figure this one out. I believe it's either the clutch, cables, synchros, slave or master cylinder. I have an h22a non lsd tranny currently have a stage 4 Bully clutch that is has the rating to handle the power. I am making 400whp and 300lbs/tq. Now the problem is at the track I have a really hard time shifting at high rpm's <6500rpm's. At lower rpm's it shifts fine, no grinds or anything, it's just at higher rpms's. I searched around, but haven't found out a for sure solution. Anyone have any ideas?? Thanks
What exactly is the problem? Does it not go into the gate, feels like it hits a wall? Does it grind? Which gears? It can be a couple of things.
What type of mounts are you running? Too much engine/trans movement during shifts can cause misshifts.
Too much play in the shift linkage from a loose joint on the shift rod or worn bushings can cause shifting issues.
Improper adjustment of the clutch can cause shifting issues.
A bad pressure plate or sprung clutch disc can cause shifting issues.
Internal tranny problems like Worn syncros/hub/slider/gear or bent/worn shift fork/shift change assembly can cause shifting problems.
I'd check the throw of your clutch. Adjust the Pedal. If your clutch is disengaging at the bottom then extend the plunger so that it will disengage sooner.
