Trouble shifting at high rpms's
Trying to figure this one out. I believe it's either the clutch, cables, synchros, slave or master cylinder. I have an h22a non lsd tranny currently have a stage 4 Bully clutch that is has the rating to handle the power. I am making 400whp and 300lbs/tq. Now the problem is at the track I have a really hard time shifting at high rpm's <6500rpm's. At lower rpm's it shifts fine, no grinds or anything, it's just at higher rpms's. I searched around, but haven't found out a for sure solution. Anyone have any ideas?? Thanks
Re: Trouble shifting at high rpms's
How's your motor mounts. You can try to bleed the slave and what fluid is in the trans?. Also while your watching the cables as your buddy goes threw the gears make sure there engaging all the way.
EGmmBAH
08-11-2005 05:57 PM
