more power=transmission problems
Old Sep 11, 2010 | 07:45 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default more power=transmission problems
Went to the track today for the first time all year since the new build and at high rpm's I had a lot of difficulty changing gears, from 1 to 2nd or 2nd to 3rd. The only way I was able to get it into gear was to shift very slowly and of course this is not the best for good times at the track. I wasn't able to shift quickly because it just wouldnt get into gear. My clutch is fine. A friend of mine is thinking it might be the shift cables which havent been changed. I have a 1992 Accord making 375whp on a boosted h22a. The clutch is not slipping and the transmission shifts fine while driving it on the street, it was really just at higher rpm's. Any ideas? Thanks
Old Sep 11, 2010 | 09:38 PM
slowtegkauai's Avatar
Default Re: more power=transmission problems
ow much clutch pedal free play do you have?
Old Sep 12, 2010 | 05:37 AM
Turbo-LS's Avatar
Clutch isn't fully disengaging. You either have air in the line a bad master or slave or to much freplay in he pedal and need to adjust the rod length
Old Sep 12, 2010 | 09:11 AM
never heard of "clutch drag" before, but thanks to another member here who mentioned it, I d found that this could be the problem. But again the problem only happens at higher rpm's
Definition: Drag
Clutch drag occurs when the disc attached to the clutch pedal continues to spin even after the clutch has been released.
Symptoms: Drag
Clutch drag is usually recognized by difficulty shifting gears. This may or may not be associated with a grinding sound.
Causes: Drag
Causes of clutch drag vary depending on clutch type. Generally, some common causes are problems with binding cables, pedal brackets and the master or slave cylinders.
turbinedteg7
Jul 13, 2011 08:30 AM
lokodog
Dec 25, 2005 09:39 PM
allmotorls95
Feb 26, 2003 02:44 PM
JMU R1
12
Sep 26, 2001 09:39 AM
JMU R1
Sep 17, 2001 12:20 PM
