H22A4 Transmission Issue!!??!
The car shifts into gears fine but the car will not move when in gear. Tried every gear and still no movement. I have the front end up on jack stands and started the car put it in first the wheels spin but when I had someone grab and hold down the wheel they were able to stop the wheels from spinning when in gear. Just installed a competition twin disc and double checked everything to make sure it was installed correctly found nothing wrong. On H22 trans they have a little opening where you can see the flywheel/clutch I had one of the axles put in and turned the axle a few times but the flywheel/clutch wasn't moving. I have a Quaife LSD not sure what the problem is here. Experts please HELP!!!??!
1st thing...
Did the trans work before?
Have you had the case apart???
If so why did you atke it apart and what did you do. HIGHLY doubtfull IF its truly a LSD diff that ANYTHING is wrong with it. If you spin one wheel and grab the other it WILL stop.
I know these things (H trans) well, ill do what I can to help you
ALWAYSS after assembling or RnR ing ut the trans in every g3ear to make sure the forks arent binding and spin the shaft save you the time having to take it in n out
PM me your number and Ill give you a call...
[QUOTE=extralargenog;45216084]1st thing...
PM me your number and Ill give you a call...[/QUOTE
The trans use to work before. I took the case apart when I installed the Quaife LSD when I put it together its still worked. So I just sent my trans out to Dave who is very helpful at Synchrotech Transmisson and had it rebuilt. Can't wait to get it back next week to install. Thanks for the reply.
