Can i Solder the ignition coil spring?
Old Apr 25, 2011 | 05:54 AM
ezcape's Avatar
Default Can i Solder the ignition coil spring?
So the spring on the ignition coil keeps loosen or falling off the ignition coil and making no connection to the distrubitor cap. So at times my car runs sluggish or doesn't want to start because of the spring falling off. I was seeing if it's safe to solder the spring to the ignition coil so it wont fall off again. Is that safe and will it still make a good connection to the cap? thanks
Origin
Mar 28, 2004 04:57 PM
jdhealy
May 1, 2003 09:56 PM
