E85 integra code 43 (fuel system) help
Old Apr 24, 2011 | 09:04 PM
Tong.Y's Avatar
Default E85 integra code 43 (fuel system) help
i have a all motor mild build gsr block itr head running on e85:
right now it's throwing a check engine light and maintenance required lighting.
checked out the ecu code and it's turned out to be code 43 (fuel system)..
some times my car starts but then at times it doesnt.. i thought i was because of the viper alarm kill switch but i guess its not because it's bogging during start up. fuel mileage goes up and performance is down. so i'm really guessing it's the fuel filter.. any other suggestion?
Old Apr 24, 2011 | 09:29 PM
Tong.Y's Avatar
Default Re: E85 integra code 43 (fuel system) help
it idles rough as it gets warmer
Old Apr 24, 2011 | 10:48 PM
rlacsamana1989's Avatar
start with the cheap solutions first
fuel filter replacement, 20 bucks for the filter and 15 mins of your time.
add a fuel injector cleaner when you next fill up. 3 or 4 bucks at an auto store
if still is then i'd say your fuel pump might be going out.
which is a little more costly
my car would have problems starting and also die sometimes while idle and i replaced the fuel filter and added cleaner and it was all good but there that may not be the case for your situation but its a good place to start
Old Apr 24, 2011 | 10:57 PM
Tong.Y's Avatar
fuel injector cleaner work for e85?
Old Apr 24, 2011 | 11:34 PM
mouab18c1's Avatar
Are you tuned?
Old Apr 25, 2011 | 12:13 AM
don't believe it would hurt but i don't think you would need to use fuel injector cleaner because e85 keeps it pretty clean, i was just letting you know what i've done. start with fuel filter and see how it goes
Old Apr 25, 2011 | 03:54 AM
Dogginator's Avatar
Daisy... Daisy...
What did you do to upgrade the fues system to handle the corrosive nature of E85? I have not looked into what is required, but ethanol will corrode aluminum.
Disregard the Maintenance Required light, as it is merely a timer.
Old Apr 25, 2011 | 08:08 AM
Tong.Y's Avatar
rc injectors and walbro fuel pump.. forgot injector size. i thought injector cleaner would only work on pump gas vehicals? are they ok on e85 cars?
Old Apr 25, 2011 | 08:44 AM
Dogginator's Avatar
Daisy... Daisy...
I think that the aluminum fuel rail would not like the E85 either. Go look in the forced induction forum for some E85 conversions. They should cover the details of what was required.
hatchet_honda
Jul 26, 2010 08:54 PM
rbizzell30
May 9, 2009 04:27 AM
RunninEg6
10
Feb 11, 2008 09:06 PM
cincispeedemon
Nov 22, 2004 05:51 PM
IwanAturBo
Mar 16, 2003 06:53 PM
