91 axle prob EF
Old Apr 24, 2011 | 06:30 PM
EF_NITROUS_FEED's Avatar
Default 91 axle prob EF
Ok this is my setup , I have a D15B Vtec with a DOHC ZC tranny and i cannot get the driver side axle to work correctly. I am using my stock axle with a 27 spline differential bearing end on it , the end is like 1/8 of a inch too short and will NOT lock into the diff. And I cannot use a half shaft. So i need to know if there is a axle that will work correctly . Or a axle end that will fit my axle/bearings that is a lil bit longer splines to lock in and keep from coming out and spray tranny fluid everywhere !!!!
Old Apr 24, 2011 | 06:42 PM
intense4thgen's Avatar
Default Re: 91 axle prob EF
thats a obd1 motor so maybe try a 92-95 axle sorry but all the dohc zc trannys ive ever owned have used a half shaft and integra axles
Old Apr 24, 2011 | 06:54 PM
ill look into that homie!
Old Apr 24, 2011 | 07:27 PM
fbcfab's Avatar
i think i had to use a prelude on mine but its been along time since i had that set up
Old Apr 24, 2011 | 07:37 PM
can you tell me a year??????
Old Apr 24, 2011 | 08:07 PM
92???????
Old Apr 24, 2011 | 08:46 PM
wantboost's Avatar
Who is Mr Robot?
umm.. wrong section?
Old Apr 24, 2011 | 08:58 PM
you will be ok pimp
Old Apr 24, 2011 | 10:28 PM
wantboost's Avatar
Who is Mr Robot?
maybe you should learn where to post things so you can get useful answers.. tool
Old Apr 24, 2011 | 10:53 PM
eppymoto69's Avatar
damn this is just as bad as Carolina Hondas
Old Apr 24, 2011 | 11:39 PM
bitchhhhhhesssssssssssss i could care less about HT!!!
EF_NITROUS_FEED
Transmission & Drivetrain
Aug 10, 2018 09:58 AM
Cap'N Chronic
Jun 29, 2011 12:54 PM
eppymoto69
Apr 24, 2011 09:30 PM
Momentum
Sep 2, 2010 10:06 AM
ktp1798
Nov 29, 2005 08:51 PM
