D16 journey to 400HP begins!
Old Apr 23, 2011 | 09:05 AM
Freshdot's Avatar
Default D16 journey to 400HP begins!
Engine: D16Z6
Head:
- bisimoto 2.4
- bisimoto springs + retainers
- supertech black nitride valves
- AEM cam gear
- head ported, milled, new seals + bronze guides
- ported oem intake manifold
Block:
- JE 9.0:1 pistons
- Scat Rods
- Clevite bearings
Fuel:
- RC 750's
- walbro 255
- AEM FPR + rail
Turbo:
- Greddy 18G
- Edelbrock log manifold
- 14psi wastegate
- ATP 3" Vband outlet
- Custom 3" downpipe
- PWM boost by gear 14psi 1st and 2nd, 23psi 3rd, 4th, 5th
- 3" exhaust to vibrant street power, no cat
- HKS SSQV
Transmission:
- Synchrotech full rebuild kit
- Competition stage 4 cermamic
- Competition ultra light flywheel
MISC:
- Hondata s300 + 4 bar MAP
- All seals and gaskets replaced
- Gates racing timing belt
- Honda oil pump, water pump, tensioner
- Mishimoto radiator
- painted, tucked, shaved bay
- Hasport 88A mounts
wish me luck. pics coming soon.
Old Apr 23, 2011 | 10:51 AM
EJ1civic coupe's Avatar
Default Re: D16 journey to 400HP begins!
nice setup you got going for the little D..good luck with the build man
Old Apr 23, 2011 | 11:11 AM
welfarepc's Avatar
i think u should get larger injectors. the 750s should get you to 400whp but might be over 80% duty
you should get yourself a different turbo imho. a t3/t4 would be a better option and inexpensive. ditch the cast manifold, go tubular with decently long runners. this helps prevent cross contamination - spent exhaust backing into adjacent cylinders.
good luck
Old Apr 23, 2011 | 12:17 PM
Freshdot's Avatar
thanx alot guys, i know i'm pushing this 18G to its limit. but i feel the cam will make up for it. next season i'm going to go with a new manifold and a GT30 or 35 and make some more power. i just want to see what this 18G can really do, i know most guys don't push these to the max. with the money i spent on the build it left my pockets hopeless for a new turbo
what is the downside to running 80% duty cycle on the injectors? i'm very unclear on this.
Old Apr 25, 2011 | 11:05 AM
welfarepc's Avatar
all the cam in the world wont turn hot air into cold air
running injectors past 80% duty stresses them and can promote failure.
Old Apr 25, 2011 | 11:29 AM
wantboost's Avatar
Who is Mr Robot?
I lol'd. Hard
Old Apr 25, 2011 | 02:44 PM
Freshdot's Avatar
what PSI do you think will be best?
and also this is only for this year..i drive the car once a week if that much, so figure about 16 sundays this year. then i will be switching to GT30, external, and ramhorn
Old Apr 25, 2011 | 02:50 PM
wantboost's Avatar
Who is Mr Robot?
You'd be better off buying a hair dryer and running it.... thats all an 18g is at those boost levels
Old Apr 25, 2011 | 03:28 PM
94GSRMR's Avatar
any pics YET?
Old Apr 26, 2011 | 08:27 AM
Ant@backyardracing's Avatar
i would also go t04e, great turbo if your on a budget, theres loads about to for spares etc.
we ran 750`s to ~475hp on our D16, at stock base pressure, if you run 50psi base you will keep that duty a tad lower, as long as the pump can flow what you need at that pressure.
log also worked fine for me at over 400...
Old Apr 26, 2011 | 03:15 PM
Freshdot's Avatar
^^^ awesome reply man, just the confidence i needed. alot of people knock the 18G and log mani..but i think with my engine build this D16 is gonna have some real potential.
here's some pics guys!! only have shitty cell phone ones now.
how she looked before tear down, made 230whp on just 10PSI with 310cc injectors and 255..STOCK EVERYTHING ELSE.
progress pics..
did a full synchrotech rebuild with carbon sync's
painting and shaving:
intake manifold
Old Apr 26, 2011 | 03:28 PM
welfarepc's Avatar
no LSD? hmmm
oh well i hope u make ur goal. it would be impressive thats for sure!
Old Apr 26, 2011 | 03:33 PM
Freshdot's Avatar
$$$$$ situation killed me after buying all the parts for my build dude, i really wanted an MFactory but just couldn't swing it..will be buying one next year when i go bigger turbo and stuff..thanx for the well wishing dude, i'm hella stoked/nervous as ****.
degreeing the cam has got me concerned lol
Old May 28, 2011 | 08:21 AM
tasco's Avatar
to those that are suggesting a t3/t4. what would be a good size for 400hp on d16?
Old May 28, 2011 | 10:15 AM
1.5Slowmatic's Avatar
thats kind of subjective. depends on your goals, rest of the build ect ect. there are lots of turbos that can hit 400hp. it just depends on what you plan to do. if your just DD'ing id say shoot for something smaller as a 400hp D on the streets will be a bitch.
Old May 28, 2011 | 10:57 AM
AlexDphoto's Avatar
my buddy on a built D made 401 @25psi on a 57trim I believe.
Old May 28, 2011 | 02:36 PM
303villain's Avatar
If you can pull that off on the 18g it would be impressive for sure but it's definitely just blowing hot air. Set up looks really clean though. Good luck!
Freshdot
Nov 27, 2012 01:43 PM
importeclipsegst
Sep 27, 2011 11:11 AM
Hondarookie93
Oct 30, 2010 04:58 PM
iroc-zintegra
May 17, 2008 06:14 PM
mntdewred
Oct 14, 2002 06:41 PM
