Back from the Dyno-turbo gsr pt67
Just got home from the dyno, made 375whp on 10-11psi pump gas and 593whp on 25psi race gas. Car could easy make over 600whp but having problems with the wasegate, the boost wont go past 25psi. Anyways I will post the dyno graph soon, its late Im going to bed!
Re: Back from the Dyno-turbo gsr pt67 (tygsr)
Great numbers. What size wastegate are you using? Also, do you have a dyno sheet? I would love to see the powerband.
Re: Back from the Dyno-turbo gsr pt67 (0x64)
I do have a dyno graph but not a scanner. When I get time I will go to my buddies house to scan. TO be honest, the car should have made more power. We were having issues with the ignition system. I think I may have a bad MSD digital 6. For all those with questions about the setup...Oh and torque was around 390ft/lb..
b18c1
81.5mm RS machine sleeves
Endyn Roller wave pistons 9:5:1
Manley Rods
RS machine valve springs and retainers
Mild port job
Precision pt67 P trim
SFP race manifold
Tial 40mm
Tial 50mm BOV
Precision 600hp intercooler
MSD digital 6
HVC coil
Precision 880 injectors
Walbro 255 high flow
JG Intake manifold
stock tb
Hondata 3b
hmm I think thats it..
Modified by tygsr at 10:06 AM 7/10/2004
b18c1
Manley Rods
Mild port job
SFP race manifold
Tial 40mm
Tial 50mm BOV
MSD digital 6
HVC coil
JG Intake manifold
stock tb
Hondata 3b
Good numbers man. What boost level do you plan on running on the streets?
There you go...Hondata is what I wanted to see.
Modified by Blown90hatcH at 10:11 AM 7/10/2004
Re: Back from the Dyno-turbo gsr pt67 (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">Running off an FMU too. Good numbers man. What boost level do you plan on running on the streets?</TD></TR></TABLE>
Umm Im not running off an FMU, but thanks anyways I plan on running 11psi or so on the street, whatever that damn wastegate decides..
Re: Back from the Dyno-turbo gsr pt67 (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 »</TD></TR><TR><TD CLASS="quote">Good numbers, the PT67 proves again what power it can make</TD></TR></TABLE>
Ya this turbo is sick. I am going to have some more tuning done, I know it can make more power than that..
Props to Cortney Green on tuning and Jasen Penman for use of the Dyno
wow sick numbers, man....justwondering, is that pt67 some type of variant of the grand national turbo, it is also called a pt67, and pt62, just wondering
Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">Well. . He's only running 81.5mm pistons so thats just over 1.8L right?</TD></TR></TABLE>
Stock bore is 81mm and that gives the GSR like 1788cc so 81.5 might be right at 1.8. Someone correct me if I'm wrong . . .
12 Years Strong
Re: (AVATAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR »</TD></TR><TR><TD CLASS="quote">
Stock bore is 81mm and that gives the GSR like 1788cc so 81.5 might be right at 1.8. Someone correct me if I'm wrong . . .</TD></TR></TABLE>
Sounds about right to me
Re: (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">Do you have the block GSR that has been sitting outside his shop for like the last 2 months? And just got his motor built?</TD></TR></TABLE>
No my gsr is white. Cortney built my motor.
Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">wow sick numbers, man....justwondering, is that pt67 some type of variant of the grand national turbo, it is also called a pt67, and pt62, just wondering</TD></TR></TABLE>
Yes, but with different turbine housings. The PT67 is also the same thing as HKS T04R but again with different turbine and compressor housings.
Good #s.
art
Good #s.
art
Holy $hit!!! that's insane to have that much power in an integra! What kit or turbo are you running in that thing? Also I live in TN right now but I am from Layton Utah. Don't see very many people from utah on the forums.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tygsr »</TD></TR><TR><TD CLASS="quote">
b18c1
Manley Rods
Mild port job
SFP race manifold
Tial 40mm
Tial 50mm BOV
MSD digital 6
HVC coil
JG Intake manifold
stock tb
Hondata 3b
Modified by tygsr at 10:06 AM 7/10/2004</TD></TR></TABLE>
i guess u must of missed this post.....
b18c1
Manley Rods
Mild port job
SFP race manifold
Tial 40mm
Tial 50mm BOV
MSD digital 6
HVC coil
JG Intake manifold
stock tb
Hondata 3b
