B18C1" ALL MOTOR "
Old Apr 23, 2011 | 12:41 AM
pithor-c1's Avatar
Default B18C1" ALL MOTOR "
Hiiiii my FRIEND`s< I NEED SOME HELP WHIT MY LITTLE REBUILT ON MY B18C1"EJ8"...
_here's what I have thought about doing, I hope everyone's help me and guide me as necessary and correct, thank you very much!!!!!!
B18C1: VIRGIN HEAD 81X89MM
-81MM CP PISTONS CR 12.5:1 OR " ARIAS 81MM CR 12-1 "
-HIGHEND HEADER
-EAGLE RODS H-BEAM.
-SUPERTECH FULL VALVETRAIN KIT WHIT FLAT VALVES.
-SKUNK2 CAMS PRO 1+ OR PRO 2 +? OR TODA SPEC "C" ?
-AEM TRU TIME CAM GEARS.
-P72-2 "OBD2-A TO OBD1 " HONDATA S300
-EDELBROK VICTOR X.
-THROTTLE BODY 72MM" BDL,BLOX,S2 "
-310 OR 440 INJECTORS " RC,PRECISION,OR WHITOUT BRAND"?
-AEM FUEL RAIL AND FUEL PRESSURE.
-WALBRO PUMP 255LPH.
-TYPE R OIL PUMP.
-OEM HEAD GASKET
-ARP HEAD STUD`S
-OEM MAIN AND RODS CONNECTING BEARINGS " GREEN`S "
-S80/ 4.785.
-ACT PRESSURE PLATE,CLUTCH AND 9LB FLYWHEEL.
-INNOVATIVE MOUNTS " STREET AND TRACK 75A "
^^^^^^^I HOPE YOUR HELP AND OPINIONS GUYS ... this project is for my car daily., and also for 1 / 4 mile ... I wonder if these modifications, the car would be around the 13 `s @ 1 / 4 mile? and also which parts to change or improve? ^^^^^^^^^^^
Old Apr 23, 2011 | 01:03 AM
ttp's Avatar
ttp
Default Re: B18C1" ALL MOTOR "
nice set up mate About the cams - i would l go for stage 3. Did you considered putting in ITB?
it you looking for 13s on 1/4 you should also remember about the weight. HP is not everything
Old Apr 23, 2011 | 05:49 AM
flavio's Avatar
b18c1 doesn't have 81x89
it's 81mm bore x 87mm stroke
81x89 it's b18a/b LS
change the victor X for an performerX/itr/sk2
Old Apr 23, 2011 | 07:20 AM
DA93teg87's Avatar
Maybe he's going to use a stroker kit or a LS crank and LS rods. My guess is he forgot to inform us on that part.
Old Apr 24, 2011 | 02:52 PM
pithor-c1's Avatar
I know, I have considered the weight too, and I changed all "doors, trunk, the entire front" etc ".. and because I like to go with the ITB` s.., give good results!, but unfortunately in my country "El Salvador"everything is envy skills = (, and few people know how to put the ITB `s," ERICK `s RACING" when he comes sometimes "and 2 more" and thanks for the advice friend = D ... but that's not the problem ... and I know that the "b18c1"His stroke is 87.2, so I decided to go to "LS" STROKE and "B20" rods to make 1885cc "B19" ... and on the cams because I say the pro s2 +1 are best for street, even the pro s2 +2 are good for street and track,, but one listen, really have to see results and experiences on these cams S2 PRO SERIES! someone will have results or some sort of set-up similar to this with CAMS S2?? THANK `S
Old Apr 24, 2011 | 04:49 PM
bambam's Avatar
Actually, its 87.2
Allmotorpride
12
Feb 20, 2017 02:53 PM
chickenbandit
Oct 7, 2014 09:00 AM
kou-integra98
Feb 3, 2014 11:28 PM
Drew17th
Nov 30, 2012 08:11 AM
dytech
16
Jul 28, 2011 11:58 AM
