SPEEDOMETER and ODOMETER is not working!!!
Old Apr 22, 2011 | 07:04 PM
t-del28's Avatar
Post SPEEDOMETER and ODOMETER is not working!!!
why is my 1997 del sol speedometer and odometer is not working????
the RPM, FUEL, TEMP. GAUGES IS WORKING FINE ALSO CEL did not showed.....
there's a thing that I took the Vehicle Speed Sensor (VSS) out from GSR tranny and to put NEW tranny fluid in it....
i cleaned inside the connector for corrosion and tested on orange wire lead and its read at 9V...im wondering wht is the problem that does affect my speedometer and odometer is not working???
WHAT MIGHT BE THE PROBLEM???
Old Apr 23, 2011 | 06:40 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: SPEEDOMETER and ODOMETER is not working!!!
Why are you asking about a del Sol in the Integra forum? A VSS is a VSS. You have a wiring issue. Does the VSS output pulse as the wheels rotate?
Dustinninja
Transmission & Drivetrain
Nov 12, 2017 03:56 PM
Bipolarcivic
12
Mar 27, 2016 03:34 PM
t-del28
15
Apr 25, 2011 01:10 PM
vaptuning
Feb 18, 2010 08:13 PM
90accord94
Jun 24, 2005 07:38 AM
