problem with tacho and speedo (del sol)
Hello! I am a new user. I am from Latvia. This is the small country in Europe, cause my english language is with mistakes.
I have Honda Del Sol 92.year. D16z6 engine code. I have a problem with speedometer and tachometer. They often don't work both, or one of them. For example, when I turn on engine, they don't work, but after 5 minutes they work(or one of them). Other gauges work correctly. What the problem can be? Thanks
Re: problem with tacho and speedo (del sol)
I have a similar issue, mine is with the tach. It often works, but sometimes it doesn't. I bought a VSS and never installed it, I guess I learned to live with it. Now since you mentioned your speedo has the same problem, then I would try checking speedo cable connection and the vss.
Good luck, let us know if you find a solution.
Check your ICM located in your dizzy. When your tach doesn't work, or jumps it usually means that your ICM goes bad. B/c it is connected to the tach and sends a signal to it.
Or could possibly be a wiring issue since the speedo isn't working also, I'm not 100% but hope this helps.
i would check the connectors on the back of the cluster ive seen them come loose before especially if u go down real bumpy roads or the cluster has been messed with before and where not fully snapped back in to the socket
Good luck
98, civic, connection, d16z6, del, diagnostic, honda, integra, problems, sol, speedo, speedometer, tach, tachometer, working, works
