Turbo blanket bad idea????
Old Apr 22, 2011 | 03:57 AM
Stopsign32v's Avatar
Loved
Default Turbo blanket bad idea????
I've ran one before and had no problems, although the car wasn't turboed for long. The other day I was talking to Precision on the phone about their opinion on coating and who they suggested. I mentioned I wanted to keep the heat down in the engine bay as much as possible and I was told they do not like using turbo blankets because they trap so much heat in where the blades are.
Old Apr 22, 2011 | 04:19 AM
fcluddington's Avatar
Default Re: Turbo blanket bad idea????
Tell them to design a better blade.lol The blankets are used on many hi HP turbos and put on by their manufacture.
Old Apr 22, 2011 | 05:43 AM
DRAGLS's Avatar
Turbo blankets really raise the possibility of coking. They really take a toll on the shaft and bearing
on the exhaust side.
Old Apr 22, 2011 | 07:08 AM
Loved
I'm really questioning now if a blanket would be a good idea for a 100% DD.
Just thinking out loud here but I'd imagine exhaust housing size and amount of boost would play a factor too.
Old Apr 22, 2011 | 07:55 AM
DelSolMarine's Avatar
Ive been running the T1 blanket on my car with no problems... If you have a properly circulating oil feed and return to the turbo I dont see the problem...
I am also running a Precision 6265 so Precision doubting their own product (as the OP said) makes no sense. The blanket is directly covering the exhaust side of the turbo not the center where the oil is doing its thing. Who ever you spoke to on the phone was talking about the blades which are being directly covered but really... they are already seeing a lot of heat...
Old Apr 22, 2011 | 08:02 AM
LS AzZkIkr's Avatar
Yeah man I have had mine for a year and no problems what so ever. There was a significant difference in response before and after blanket. Just be sure to have a free flowing oil return and proper restrictor for the feed line and you should be fine. And make sure they are as close to vertical as possible. I had to put mine on an angle and the turbo has been blowing oil ever since.
Old Apr 22, 2011 | 08:34 AM
93lsv_turbo's Avatar
that doesnt sound like a turbo blanket problem. im wrapping my manifold my turbo and my downpipe. i plan on using that heat for energy. i dont feel like its going to cause to much more damage then what happens when you turn the car on without the wrap
Old Apr 22, 2011 | 08:45 AM
boostedBLUfg2's Avatar
i've found the people you talk to on the phone at precision are absolute ****-heads who know little about their product. i spoke to one guy on the phone for a bit and he contradicted himself numerous times
Old Apr 22, 2011 | 12:45 PM
DRAGLS's Avatar
http://www.turbobygarrett.com/turbob...te_Papers.html
Old Apr 22, 2011 | 01:19 PM
AlexDphoto's Avatar
x2
Old Apr 22, 2011 | 06:55 PM
$amGD3's Avatar
Swaggylicious
Originally Posted by AlexDphoto
x2
x3
the guy i spoke to told me to "dont worry about it" when I asked him how much oil flow is recommended for my turbo
$MIKE$
Dec 12, 2013 02:44 AM
turboaccord77
Oct 18, 2011 06:41 AM
crazzeboost
Jul 20, 2005 07:09 AM
boostismycrack
Mar 4, 2004 07:04 PM
cr-x si
Feb 6, 2003 04:51 PM
