I'm stumped, idle bouncing
Old Apr 19, 2011 | 04:04 PM
Edwin909's Avatar
Default I'm stumped, idle bouncing
Ok so I have an obd0 lsv b16a head with b18a1 block I keep on having a idle that bounces between 1500 to 3000 and sometimes 900 to 1800 I cleaned the IACV and FITV and still have the idle issue check for a vacuum leak and nothing so I cover the bottom hole on the tb and it helped a little bit but when I covered the top hole it fixed the problem so I just replaced the IACV and still nothing I have also bled the coolant system and no help at all
Can anyone help me I might replace the FITV to see if that helps but I don't wan to slend anymore money if that not the problem
Old Apr 19, 2011 | 04:16 PM
red91g2's Avatar
Default Re: I'm stumped, idle bouncing
need a little more detail about the problem, sounds like a vaccum leak to me i know you say its not but thats what it sounds like
Old Apr 19, 2011 | 05:30 PM
Edwin909's Avatar
Ok well when I turn on the car the car revs up to 3000 then stays there for awhile then it drops to about 1500 and bounce between 1500 and 2500 but sometime when it's already warmed up and I turn on the car it'll bounce between 900 to 1800 or so I can check the vacuum hoses again if it's necessary I'm just saying that when cover the IACV hole on the tb it idles normal and I believed itto be a faulty IACV so I replaced it and still no fix
Old Apr 20, 2011 | 12:07 PM
Edwin909's Avatar
Bump?..
Old Apr 20, 2011 | 05:47 PM
netfreak's Avatar
http://www.kelownacivics.com/forum/u..._DIY#Post24001
Old Apr 20, 2011 | 06:01 PM
Edwin909's Avatar
The cold bypass valve is also known as the FITV I have already cleaned and screwed it back in. Like I said above it idles normally when I cover the 2nd hole on top not the bottom. I do thank you for trying to help me
Old Apr 20, 2011 | 06:02 PM
Edwin909's Avatar
Still need help the bouncing idle annoys me and it's taking a toll on my fuel economy:/ any help is appreciated
Old Apr 20, 2011 | 09:07 PM
Krado's Avatar
i have the same issue... adjust the idle screw?
Old Apr 20, 2011 | 09:15 PM
lazy14's Avatar
a shot in the dark but could it be sumthin with the resistor box, ive seen those cause some weird things
Old Apr 20, 2011 | 10:07 PM
Edwin909's Avatar
Aleady adjusted the idle screw
can you tell me more about the resistor box?...
Old Apr 21, 2011 | 04:32 PM
netfreak's Avatar
Little metal box right against the firewall by the driver side. Has I believe two sets of plugs running to it. If you have access to a wrecking yard just grab one from another EF and see what happens.
Old Apr 21, 2011 | 04:46 PM
0c00l's Avatar
What ecu are you running?
Old Apr 21, 2011 | 05:38 PM
Edwin909's Avatar
I know what it is I'm just want to know how that can affect my idle?....
And I'm running a stock ecu pm6 I believe with a vtec controller
Old Apr 21, 2011 | 05:52 PM
0c00l's Avatar
I didn't know a stock PM6 would run an LS/V. The fuel map and config is for a single overhead cam right? I could be wrong.
Old Apr 21, 2011 | 05:53 PM
Edwin909's Avatar
Yeah you might be right but are you sure of this so I can run a pr3 or pw0 ecu
Old Apr 21, 2011 | 06:24 PM
0c00l's Avatar
Well, I bought a PM6 a few years back to do a dpfi to mpfi and worked great. I am now building a LS/V (B18a1/B16a) PR3 head, and from my understanding you need an ecu that will run it. Now your vehicle wiring is obd0 so you would need to hack it to obd1 or use the jumper:
http://cgi.ebay.com/ebaymotors/PRE-O...#ht_2232wt_802
and run a p28 chipped with a base map for your motor.
Old Apr 21, 2011 | 06:30 PM
0c00l's Avatar
Also the fuel pressure from the stock fuel pump on the EF shouldn't be enough to run your new injector setup. If it's the OEM it was designed to run two injectors on the DPFI setup.
Old Apr 21, 2011 | 07:46 PM
Edwin909's Avatar
Well I have an si so it was never dpfi and unless I'm going to go big on my lsv which I'm not ima stick to obd0 but I will pick up an pr3 or pw0 ecu to see if that helps
liquidx
Oct 5, 2009 06:58 PM
_kiid
May 7, 2009 03:01 AM
b16a4
22
Jun 1, 2007 02:37 AM
the.hamburglar
May 10, 2007 08:46 PM
kihun_cha
20
Sep 17, 2004 03:18 PM
