crankcase venting question?
Old Apr 19, 2011 | 06:44 AM
bcumbie's Avatar
Default crankcase venting question?
I'm currently gathering the rest of my stuff for my turbo install on my hatch. I'm wanting to do away with my stock pcv and set up a vent to that atmosphere setup. Seems like people are goin crazy with vents 4 out of the valve cover.2 from the block etc.. I'm not saying more isn't better, but is it necessary? On my setup I'm thinking just venting the block will be adequate.
Set-up as follows....
Stock b18c gsr with s2s1 cams
Full race ramhorn
Garrett t3/t4 .57 trim
Around 10-12 psi daily driven.
Of course other stuff like injectors, hondata, etc..
Thanks in advance.
_brandon_
Old Apr 19, 2011 | 09:44 AM
Tootsie7944's Avatar
Default Re: crankcase venting question?
I'd get the T1 catch can...I only ran 2 lines off the back of it....couldn't fit the front 2 with the full-race manifold.
Old Apr 19, 2011 | 11:26 AM
93lsv_turbo's Avatar
dont have to go over board with a T1 setup if you dont want to. you should be good with juss 2 off the front or 2 off the back. find which ever works for you and use it
Old Apr 19, 2011 | 12:49 PM
bcumbie's Avatar
Thanks for the input guys. I really like the t1 setup. Tony tuned my old n/a setup. Good guy.
Old Apr 19, 2011 | 01:02 PM
met's Avatar
met
the t1 looks nice in the picture, I havent seen one in person. Just 500 for a vent system seems really extreme.
Old Apr 19, 2011 | 01:14 PM
its not for the everyday dd honda fo sho
Old Apr 19, 2011 | 01:25 PM
SovXietday's Avatar
I bought all the raw materials for something like $250 using JEGS fittings and not as many as the T1 kit has. Now I have to weld it.
It's not that extreme, the stuff is just that expensive.
Old Apr 19, 2011 | 05:04 PM
bcumbie's Avatar
I've decided to vent the valve cover and the block with -10AN lines and a custom built tank.
Old Apr 19, 2011 | 06:55 PM
bcumbie's Avatar
well doing some more research, I am thinking that if I vent the valve cover I should prob do the back of it, my full race ram horn seems like it might be in the way of venting the front. Now my question is what about baffles in the back? I looked at a old VC I had laying around and it seems if you vent from the back then you should build some kind of a baffle inside the VC?
Old Apr 19, 2011 | 07:08 PM
SovXietday's Avatar
As long as you're draining back into the block you don't need to worry about the baffles. If you aren't, you do.
Old Apr 19, 2011 | 07:30 PM
nonpoint986's Avatar
i dont drain mine back in. it looks like foamy vomit when that blow by is drained
Old Apr 20, 2011 | 04:14 AM
You can baffled it or just watch our oil level..... Thats all I do
Old Apr 20, 2011 | 05:20 AM
bcumbie's Avatar
If I do decide to baffle it. How are you guys (the ones who baffled.) doing it?
Old Apr 20, 2011 | 08:44 PM
DelSolMarine's Avatar
I have a 6 ports into a B&R fittings kit... which is probably overkill but it makes me feel more confident lol...
The rear of my B series valve cover has a L bracket welded inside to baffle the two rear ports on my valve cover. I have 2 drain backs as well.
Old Apr 20, 2011 | 09:03 PM
wantboost's Avatar
Who is Mr Robot?
i personally dont like drain back, all of the blowby byproducts can contaminate oil. i doesnt bother me to drain my catchcan every so often.... plus it allows me to monitor the motor, a full catchcan is a precursor to problems, something you might not catch early on if your catchcan drains back
Old Apr 20, 2011 | 10:08 PM
CaliforniaDad's Avatar
No-Traction = Fun
I agree!!
Old Apr 20, 2011 | 10:26 PM
JDM B20 EH2's Avatar
I have been looking into doing this as well. This post did give some helpful answers to some questions I had. I have all my -10an fittings and hose just have to get the catch can now.
Old Apr 21, 2011 | 01:38 PM
bcumbie's Avatar
So I'm guessing I could just build a baffle similar to the one on the right in the picture and not have to worry to much.
Old Apr 21, 2011 | 01:49 PM
yup sure could.
Mikeedubb
Oct 21, 2011 11:32 AM
Shadowz7429
Jan 4, 2010 10:32 AM
lsturbocoupe
Apr 2, 2008 11:46 PM
jdm_vtec
Aug 27, 2007 05:20 PM
98AcuraGS
Nov 21, 2002 10:51 PM
