Throttle Body Size
Old Apr 20, 2011 | 03:14 PM
rico892002's Avatar
Default Throttle Body Size
Hey guys i have a built turbo gsr...and currently im running the stock TB on a blox intake manifold...my set made 440whp but im going back for a retune here soon, because i got a new turbo manifold made..and for the hell of it i was gonna replace the stock 60mm for a bigger TB...The question is it really worth it? and if so what size do u guys recommend...65mm,68mm,or 70mm? thanks
Old Apr 20, 2011 | 03:15 PM
crashtke's Avatar
Default Re: Throttle Body Size
I have seen stock Sti's run into the 600's with stock 65mm
Old Apr 20, 2011 | 03:18 PM
92redhatch's Avatar
I made 522 stock b16 tb
Old Apr 20, 2011 | 03:25 PM
rico892002's Avatar
92redhatch...whats your set up?
Old Apr 20, 2011 | 03:35 PM
92redhatch's Avatar
84x89 lsvtec Topmount 6765
Old Apr 20, 2011 | 07:53 PM
sik96teg's Avatar
65mm is the largest you can get unless u get your intake mani bored out.
Old Apr 20, 2011 | 08:12 PM
DelSolMarine's Avatar
OP- im only assuming your running 2.5 inch cold side charge piping atleast which measures at 63.5mm according to a calculator. Anything bigger than that should be considered because otherwise a body neck is being created from going from piping that is 63.5mm and decreasing to 60mm as stated... while its not a major issues i would consider sending your throttle body to maxbore.com for their boring services. A cheaper alternative while still avoiding any possibilities of "sticking".
Old Apr 20, 2011 | 09:02 PM
rico892002's Avatar
delsolmarine-i see what u mean..pretty much i need to stay in the size range thats the size of my cold side(which is 2.5).. i might just get a 65mm since thats the biggest size u can run on a blox im with out port matching..i can get one pretty cheap.
Old Apr 21, 2011 | 04:04 AM
Stopsign32v's Avatar
Loved
I would go with a slightly bigger size than your charge pipe.
Old Apr 21, 2011 | 11:02 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
had my car back on the dyno with a skunk2 68mm, the shaft wasn't sealing, creating a boost leak.
We threw on an OEM s2k TB and it made identical power.
Old Apr 21, 2011 | 11:32 AM
Loved
OEM s2k tb bolts up to a B series intake? Or am I missing something?
Old Apr 21, 2011 | 01:49 PM
Mattb16teg's Avatar
Community Builder
Yes sir it does..
Old Apr 21, 2011 | 02:07 PM
Loved
What size is it? And its 100% plug and play?
Old Apr 21, 2011 | 02:32 PM
Mattb16teg's Avatar
Community Builder
It's roughly 62mm and is plug and play. Took about 5 minutes to put it on, there is no idle screw though. I can compensate through Hondata.
dc2king
30
Aug 2, 2008 05:45 AM
mike93eh2
Jan 6, 2008 08:47 PM
Kid_SiR
Jan 6, 2008 06:27 PM
B18Sleeper
Oct 24, 2005 09:20 AM
dunkd
Mar 5, 2005 01:12 AM
