Unpredictable idle and killing.
I was going down the road today and I hit the clutch and put it in neutral to stop and the engine revved down and died. It did this twice. When I would stop half the time the engine idled around 500-600rpms the other half it idled at 300-400rpms and almost kills. What is the possible cause of this? Thanks
This happened to my car a long time ago, and just recently after I put in my JRSC. The regular things to check are the idle screw on the bottom side of the throttlebody by the throttle cable. Also, make sure you don't have any vaccuum leaks. Aside from that, I guess when they're adjusting idle, you need to unplug a vaccuum line I think? I'm not quite sure of the process...maybe somebody more technical could explain?
gabrielsousa
May 2, 2014 07:53 AM
Car Tweaker
Sep 13, 2009 08:28 PM
headhunter
Aug 18, 2003 08:14 PM
