Civic 01 fog Help !
Hi , I just wire my new civic 01 fog from ebay , but it doesn't work. The connector that goes on the fuse box doesn't clip and I got only 1 wire there . I need help !!
Here the picture :
Here the wiring with the relay and fuse :
http://img198.imageshack.us/i/img0068ig.jpg/
Here you can see the red wire connected to the batterie and black to a ground spot :
http://img824.imageshack.us/i/img0069smu.jpg/
The wire that goes from the fuse to the interior of my car :
http://img535.imageshack.us/i/img0070fo.jpg/
The same wire connectec to the yellow wire with the switch thing :
http://img64.imageshack.us/i/img0076gy.jpg/
The switch with the wire in :
http://img828.imageshack.us/i/img0074me.jpg/
The green conector to the fuse box . Doesn't clip correcly :
http://img19.imageshack.us/i/img0077iy.jpg/
There is also a ground with the green conector but I forgot to take a picture.
Hope it will help
Here the picture :
http://img535.imageshack.us/i/img0070fo.jpg/The same wire connectec to the yellow wire with the switch thing :
http://img64.imageshack.us/i/img0076gy.jpg/The switch with the wire in :
http://img828.imageshack.us/i/img0074me.jpg/The green conector to the fuse box . Doesn't clip correcly :
http://img19.imageshack.us/i/img0077iy.jpg/There is also a ground with the green conector but I forgot to take a picture.
Hope it will help
I fixed your pictures.
What I did was opened each url, right-clicked each of the images, and clicked "Copy Image Location" for each one.
Then I used the "Insert Image" option (the little mountain looking icon located in the message interface) and pasted the image location into it, allowing the images to show up.
This is the third option listed at the bottom of the link I provided in my first post.
take the connector out from the clip that goes to the fuse box and then plug in the connector directly. That's what I had to do because the clip never wanted to go in the fuse box. It may come loose overtime but I havn't had a problem over 3 years now.
