car wont start, battery wiring?
Old Apr 11, 2011 | 07:59 PM
Luke G.'s Avatar
Default car wont start, battery wiring?
i just bought a new battery about a week ago, today after work i turned the key and dash lights and everything came on, then it just died completely after i tried to crank over the engine. I tried jumping it and had no luck, i jiggled the terminals and the dash lights came on, but then died again when i went to crank it over. Does this sound like a battery, or some problem with the wiring to the battery?
Old Apr 11, 2011 | 08:07 PM
Former User's Avatar
Default Re: car wont start, battery wiring?
Check the ignition switch -- see FAQs sticky.
Old Apr 11, 2011 | 08:20 PM
Luke G.'s Avatar
http://i267.photobucket.com/albums/i...cture_3412.jpg
If something is wrong then where do i go from there?
Old Apr 11, 2011 | 08:22 PM
Replace the electrical part of the ignition switch.
Old Apr 11, 2011 | 08:24 PM
Luke G.'s Avatar
could my turbo timer that i installed recently have something to do with it?
Old Apr 11, 2011 | 08:25 PM
Why would you suspect it? How did you install it?
Old Apr 11, 2011 | 08:30 PM
Luke G.'s Avatar
Well since it is wired into the ignition wiring, I followed the diagram exactly though and it works as it should.
Old Apr 11, 2011 | 08:31 PM
Did you solder and heat shrink wrap the wire splices? If not, you may want to redo it.
Old Apr 11, 2011 | 08:34 PM
Luke G.'s Avatar
Soldered, didnt use heat shrink wrap though, just electric tape, wrapped tight. It seems to change when i move around the terminals though, but when go to crank over the engine it loses all power
Old Apr 11, 2011 | 08:36 PM
What seems to change?
Old Apr 11, 2011 | 08:38 PM
Luke G.'s Avatar
i will get strong electric power it seems, fuel pump sounds normal, But then as you turn the key to start it the whole dash goes black, like no more power at all.
Old Apr 11, 2011 | 08:39 PM
I'd redo the wiring and also check the ignition switch. I think one of your wires may be loose.
Old Apr 11, 2011 | 08:40 PM
Luke G.'s Avatar
Ok, Thanks for the help.
Pagoda
Sep 15, 2014 09:30 PM
EF9_RIDER37
Jan 11, 2011 10:48 AM
Rickdogg
Dec 9, 2009 01:38 PM
DA9muthaFocka
Jan 25, 2005 05:01 PM
97itr86
Dec 26, 2004 07:07 PM
