b18a1 help
so that will work? also my car wont start. its getting spark and still wont start. fuel pump runs for about 3 seconds after key is turned then shuts off. also dizzy timing isnt set. any ideas why it wont start?
How far off is the timing?
Does it fire at all?
Do you have fuel pressure?
Are the injectors pulsing?
Have you checked valve timing?
Have you checked compression?
More info on what happened and how/when, EG; engine was just put together. 94
