Car won't start
Old Aug 22, 2011 | 03:14 PM
jimmy051702's Avatar
Default Car won't start
My car won't start earlier today the car wouldn't turn over or anything. I messed with the distributer and then tried to charge the battery and now the car turnes over and almost starts but then stops starting. Any ideas any help would be appreciated thanks
Old Aug 22, 2011 | 05:20 PM
boostedteg909's Avatar
Default Re: Car won't start
does it click but doesnt turn over? nd after u charged it did it crank slow then quit crankin??
Old Aug 22, 2011 | 05:41 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help.
Also is it an auto or manual transmission?
Any mods or is it stock?
What have you checked, other then messing with distributor, [whatever that means] and charging the batt.?
Have you checked timing, valve timing and ign. timing?
Have you checked for fuel. [fuel pressure]?
Have you checked for spark, do you have it and is it a good strong spark?
Have you checked the compression?
Have you checked for vacuum leaks?
If you have not done the above you will need to do so. 94
Old Aug 23, 2011 | 08:01 AM
Sorry I took the dizzy apart and put it back on when I did that I heard the click when turning the ignition after that I hooked up jumper cabels and the car turned over I hold down the ignition and it almost starts but doesn't but when I pump the gas a little it sounds like it's going to start more then dies I am going to check the spark plugs later today
Old Aug 23, 2011 | 11:12 AM
fcm's Avatar
fcm
Old Fart
Do you hear the fuel pump priming?
Turn ign. switch on to run, [not all the way to start], you should hear 2 "clicks", [may sound like one click] from the PGM-FI Main Relay, at the same time the CEL will turn on and you will hear the fuel pump running, [priming] after a few sec. there will be a 3rd click from the PGM-FI Main Relay and the fuel pump will turn off and so will the CEL.
Does that happen?, if so...
Turn ign. to run, wait for pump to stop priming then turn the ign. off and on again, wait for pump to stop and do it again, do this 3-4 times and then try and start the car.
Let me know what you find. 94
Old Aug 23, 2011 | 01:04 PM
I do hear the fuel pump priming but I will try to prime it a few times and let you know what happens. Thanks for the help I'm not a mechanical person at all
Old Aug 23, 2011 | 03:04 PM
Ok so I tried to let the fuel pump cycle like u said 4 times and it came closest to starting that it has but started to start and died after it died there was a kinda loud buzzing sounds that came from the bay of the car
Old Aug 23, 2011 | 05:26 PM
fcm's Avatar
fcm
Old Fart
Still need to know MM&Y of car????
I would check fuel pressure.
When was the last time fuel filter was changed? 94
Old Aug 23, 2011 | 07:46 PM
the buzzing noise is ur idle air control valve. once u turn the key off it should stop
Old Aug 24, 2011 | 07:46 AM
It's a 97 Teg gsr with a fully built 2 ltr gsr that's boosted running on Neptune
Old Aug 25, 2011 | 04:12 PM
Here's an update I tried priming the car 4 times it will start now for about 20 or 30 seconds and idle at about 500 or lower then the rpm will start to bounce down lower and it will back fire once then the lights flicker and it dies when I try it again it does the same thing
Old Aug 25, 2011 | 04:43 PM
fcm's Avatar
fcm
Old Fart
Check fuel pressure. 94
coltonbarrier
Feb 7, 2014 04:06 PM
JDM_SOHC
23
Sep 27, 2011 04:02 PM
jonnybadboi9
Jul 15, 2009 09:39 PM
kelviiv
Dec 17, 2008 11:19 AM
b18c1eg2
Aug 21, 2004 12:28 AM
