Obd2b B18b won't start up
Old Jan 17, 2013 | 04:31 AM
Ls671's Avatar
Default Obd2b B18b won't start up
I have an Integra cranks. Gets fuel, spark but won't start. Fuse for ignition coil blew last month and replaced it. Changed my battery 2days ago. Car was tranny swapped from auto to manual, still using automatic ecu. Please help. This the 3rd time it happened.
Old Jan 18, 2013 | 11:25 AM
fcm's Avatar
fcm
Old Fart
Default Re: Obd2b B18b won't start up
One of them must be missing, you need fuel, spark and compression.
If spark is good, fuel pressure is good and you have compression, then I would check timing, both valve timing and ign. timing, maybe you skipped a tooth on the timing belt.
Start by confirming valve timing is correct, then a compression test, then spark and fuel pressure. 94
Old Jan 19, 2013 | 06:01 AM
mpgmike's Avatar
How did you check for fuel? If you are just testing for pressurized fuel at the fuel rail, are the injectors opening? Noid lights plug in where the injector normally goes and blink when the signal triggers injector opening. You can get a cheap set at Harbor Freight.
Did it run before, or are you trying to start the car for the first time (new purchase)? If it ran before, what changes happened between it running and now? There might be some clues there.
Mike
Old Jan 21, 2013 | 11:30 PM
Ls671's Avatar
Mike
yes fuel is being shot from the injectos i also took each injector and cleaned them.. were dirty. the first time it did not wanna startbit was cause of my ignition coil fuse blew. my car was running real good before this happened then now it keeps failing on me and for some reason my fuses keep blowing.
Old Jan 22, 2013 | 06:49 AM
fcm's Avatar
fcm
Old Fart
If your "ignition coil" fuse is blowing, either the coil is bad, [internal short] or you have a shorted wire going to the coil. 94
Old Jan 22, 2013 | 08:08 AM
mpgmike's Avatar
Check the resistance between the primary "+" and "-" wires. There should be at least a couple of ohms (7-15 IIR). Check the resistance between the primary and coil tower. That should be pretty much an open circuit. If that's good...
Start at the coil and work your way back the harness. Look for wires near exhaust, or even laying across a shifter linkage (saw that once) that may have worn through. Look for carbon tracks on the side of the coil.
Hope this helps.
Mike
Old Jan 27, 2013 | 03:49 PM
Ls671's Avatar
Ive changed my coil and my igniter and it fixed the problem and was starting up with no problem at all. I tried starting it this morning and it didnt wanna start again. same problem is happening again. i checked my main relay for any cracks on the solder points but relay was good. then i gave it a try a couplr of hours later then it fired up easily. could it be with the weather in the morning compare to afternoon?
Old Jan 27, 2013 | 06:13 PM
Ls671's Avatar
anyone?
Happiest92Ricer
12
Jun 28, 2013 08:52 AM
EF927
Jan 25, 2010 03:54 PM
kelviiv
Dec 17, 2008 11:19 AM
dc2doi
Jan 6, 2008 01:43 PM
ericlee303
Apr 28, 2004 03:31 PM
