B20 Base Map?
Old Apr 10, 2011 | 06:29 AM
turbodcxbro's Avatar
Default B20 Base Map?
Whats up fellas, just chipped the P75 in my 94 Integra with a B20 swap, first time chipping a Honda ECU, it went really well. Started right up with no CEL at all!
Anyway, I hear many different things about the maps for a stock B20, mine ran fine for months on the stock LS maps but I did notice it would start pinging sometimes around 3-5k rpm. The motor is completely stock except for a cheapy 4-2-1 header and true 3" intake.
I'm using Crome for tuning and was wondering if any of you guys wanted to share notes, no I'm not looking for a free handout tune! I have to pick up a wideband here soon so I can get a good look at things but for now Its running pretty damn good on the LS maps which I smoothed out and added a little fuel.
What should my fuel pressure be with vac off, I'm getting conflicting answers.. Crome shows base pressure to be at 45psi?
Old Apr 10, 2011 | 11:06 AM
mouab18c1's Avatar
Default Re: B20 Base Map?
I wouldn't be adding or subtracting any fuel without a wideband.
Old Apr 10, 2011 | 11:38 AM
mtber's Avatar
Set your base ignition timing to 16 degrees.
Make sure you sync the ignition timing to your EMS.
Old Apr 10, 2011 | 04:52 PM
Base timing it set via the manual (16degrees) at least according to my light and the mark on the balancer. How do I go about making sure its "synced" to my EMS?
JDMswagSerf
Feb 7, 2016 02:50 PM
efkilla
Aug 28, 2014 10:09 AM
rexracer626
Jun 24, 2010 06:28 AM
iloveb16
Mar 28, 2007 08:04 PM
11secdx
Dec 26, 2001 08:20 AM
